New head gaskets won't start
Old Jul 28, 2013 | 10:35 PM
Andrewsvette's Avatar
Andrewsvette
Default New head gaskets won't start
Hey guys, just got my car put all back together after pulling heads and replacing head gaskets, plugs are in the right place, wires are all connected in the right place. The only thing I haven't done is bolt the exhaust manifolds back to the collectors I was hoping it would run enough to get it onto ramps so I can see what I'm doing down there. It turns over and every now and then pops like a cylinder or two try to fire... I'm about to pull my hair out because of this thing any help is appreciated!
Andrew
Old Jul 28, 2013 | 11:29 PM
45LONGCOLT's Avatar
45LONGCOLT
6th Gear
Did u pull distributor out. may have put back in 180 off
Old Jul 28, 2013 | 11:31 PM
Andrewsvette
I did not pull the optispark, just the one coil wire that was it as far as distributor
Old Jul 28, 2013 | 11:38 PM
45LONGCOLT's Avatar
45LONGCOLT
6th Gear
popping while trying to start sounds like the timing could possibly be off. Did distributor turn at all, check to see if it is loose
Old Jul 28, 2013 | 11:53 PM
Andrewsvette
I didn't move it at all, it isn't loose either. Chiltons manual says for a 1994 lt1 the ECM controls timing through cps and knock sensors and it isn't possible to adjust timing, I didn't touch either of those sensors, I'm starting to consider a valve lash issue, I lapped the valve while the heads were out the chiltons manual says to tighten rocker arm nuts to 100 inch pounds and not much else as far as setting the valve lash
Old Jul 28, 2013 | 11:57 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Ensure the coil is connected. Triple check all connections.
I bet is a plug you forgot to connect. Tomorrow is a new day
Old Jul 29, 2013 | 12:03 AM
Andrewsvette
What is the Best way to ensure it is connected I felt it pop on at both connections, I swear I have been over every single plug a dozen times, ill bet it is something simple as I have put in some hours the last couple days to get her back on the road and haven't slept much..
Old Jul 29, 2013 | 02:06 AM
96GS#007's Avatar
96GS#007
This comes up a lot. 99 people out of 100 swear they have the plug wires on all the right plugs. 98 out of 100 find they were wrong.
Old Jul 29, 2013 | 03:04 AM
mazdaverx7's Avatar
mazdaverx7
check and ensure each plug wire is correct. the first thing i would do is check for spark. check the connection at the coil and the ICM. then check to make sure the connector for the optispark did not work loose. it can happen. make sure those connectors are firmly seated and check to make sure you are getting spark.
Old Jul 29, 2013 | 04:39 AM
Cliff Harris's Avatar
Cliff Harris
I've seen that multiple times. "It turned out I had the plug wires on wrong".
I have my doubts about the valve lash setting method. Did you rotate the engine for each pair of valves? If not then they're "all honked up". I noticed on my car (1986 L98, cast iron heads) that the nuts are all 0.2" below the top of the stud. That makes a good starting point, but may be different for your engine. The point is that the distance should be about the same for all of the rocker arm nuts.
Old Jul 29, 2013 | 06:36 AM
gerardvg's Avatar
gerardvg
If the valve lash is too tight the valves wont seal and you will have 0 compression, do a compression test.
I know my shop manual said at the cylinder tdc adjust the rocker nut till you cannot turn the pushrod by hand, then turn one full turn.
With my new engine i did the same, she wouldn't start turned out the new lifters only required 1/4 to half a turn...
Something for thought
Old Jul 29, 2013 | 10:20 AM
Andrewsvette
I verified plug wiring last night, I did rotate the motor as I adjusted valve lash, I'm about to go get started again for today and give it a fresh look over
Old Jul 29, 2013 | 10:22 AM
383vett's Avatar
383vett
Here's your problem. The lifter preload has to be set when the lifter is on the cam's base circle. You might have bent pushrods or who knows what else if you just torqued the rocker arm adjusting nuts to 100 in lbs.
Old Jul 29, 2013 | 11:13 AM
Andrewsvette
that's what I was afraid of but the nuts look like they are in the same place as they were when I took them off, Im going to go pull valve covers again to make sure everything is still good and possibly re-lash the valves again
Old Jul 29, 2013 | 11:22 AM
383vett's Avatar
383vett
There should be a sticky on how to adjust lifter preload. If not, search for it. The manual should have spelled it out better than the 100 in/lb torque method.
Old Jul 29, 2013 | 11:26 AM
Andrewsvette
yea I would think so too normally I get the Haynes manual instead of the Chilton for some reason I like them a little bit better. Im pretty sure this is a valve lash issue I just went out and loosened up the valves on the pass. side and give it a quick crank it actually fired more then one or two cylinders at the same time. any tips for setting the preload?
Old Jul 29, 2013 | 12:50 PM
Andrewsvette
ok after going through the driver side and completely resetting the pre load I am pretty sure this is the issue, I'll post back when I get the thing fired up thanks for the help guys, hopefully I'll be cruising tonight!
To New head gaskets won't start
Old Jul 29, 2013 | 01:01 PM
96GS#007's Avatar
96GS#007
You want the *****Helms**** Factory Service Manual. The others pale in comparison. Hopefully it is just your valve lash. Good suggestion by those above that mentioned it
Old Jul 29, 2013 | 02:05 PM
Andrewsvette
the preload was the issue for sure, I set all of them again and it fired right up, all I need to do now is bolt up the collectors and maybe chase down an exhaust leak and I should be good to go! thanks again for all the help
Old Jul 29, 2013 | 02:53 PM
96GS#007's Avatar
96GS#007
Nice work and congrats on being one of the few that gets the plug wires on right!
