HELP! can't find dist adjust screw
Old Aug 1, 2013 | 11:38 AM
rgouette's Avatar
rgouette
hmm
Old Aug 1, 2013 | 07:45 PM
vetteoz's Avatar
vetteoz
Originally Posted by GQ-ROD
.... chances are he would miss that the harmonic balancer bolt might have come loose and destroy his engine,
better safe than sorry .
The balancer is a press ( tight ) fit on the crank
Plenty of SBC's didn't even have the balancer bolt from the factory
More likely to have problems ( age related ) with the rubber disintegrating and the balancer coming apart leaving the hub with
NO bolt still attached to the crankshaft
Old Aug 2, 2013 | 01:28 AM
Cliff Harris's Avatar
Cliff Harris
...And sometimes the outer ring of the harmonic balancer walks into the timing chain cover and grinds a hole in it (fixed with JB Weld about 10 years ago -- new cover on there now):
