where is your FP ground wire?
Old Aug 1, 2013 | 06:17 PM
rgouette's Avatar
rgouette
Default where is your FP ground wire?
Out of curiosity, where do you find that your fuel pump (black) wire is grounded?
Old Aug 2, 2013 | 01:20 AM
Cliff Harris's Avatar
Cliff Harris
I have never traced that one (mine works fine), but I have seen in another post about a month ago that it is grounded at G401, which is near the rear compartment courtesy light on the passenger side. Here's a diagram from the '86 FSM (yours might be different):
Old Aug 2, 2013 | 08:03 AM
rgouette's Avatar
rgouette
whoa
that's interesting.
because all I have is about a 12" length of black wire coming out
of the connector...
Old Aug 2, 2013 | 11:55 AM
SunCr's Avatar
SunCr
Most have two, often spliced together - one for the Pump the other for the Tank which will keep static electricity from blowing you up when you fill it up. At least one should run to the frame below the Tank. If someone has replaced the Tank, they may have removed or cut that ground wire. Put it back.
Old Aug 2, 2013 | 12:04 PM
rgouette's Avatar
rgouette
hmmm
To where is your FP ground wire?
