Check Engine Light 1991 C4
Old Aug 2, 2013 | 11:58 AM
Sterling Silver's Avatar
Sterling Silver
4th Gear
Default Check Engine Light 1991 C4
I have a 1991 coupe model that seems to have a faulty temp sensor and the check engine light comes on. I think it is a temperature sensor because during the drive in the morining while it is cooler, the light doesn't come on. In the heat of the afternoon it does come on. The engine guage however reads relatively cool even though the light comes on. Are there 2 different sensors?
Old Aug 2, 2013 | 10:58 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Read the first one on the list here. In fact - read the entire section. You will learn a bunch
http://forums.corvetteforum.com/c4-g...ps-w-pics.html
Old Aug 3, 2013 | 02:23 AM
vetteoz's Avatar
vetteoz
Yes
The temp gauge sender is completely independent from the coolant temp sensor (CTS ) that sends the engine temp
signal to the computer that generates the SES light.
Read
http://forums.corvetteforum.com/c4-t...-ecm-temp.html
Pull the codes as described in the link to see why the SES light is showing
To Check Engine Light 1991 C4
