I'm defeated...
probably done for the day, but I'll try that too..
unless something else trumps that as a possibility
the terminal g idea is a great test but is kinda jumping ahead a lil as its adding more wire and possibilitys for more issues, i would test direct at the pump as you were trying first then once you get pump going and fuel then move to testing it at g terminal..
if it were me i would either get a roll of decent (average car wiring) wire and cut 2 pieces to use for verious future testing.. one for poss. one for neg.
and i would just jump direct from the battery in the car to the fp, can use one wire and just try jumping the possitive first as this will also be testing your ground at the same time. if fp doesnt run then jump the ground from batt back too.
just how i would do it but to each there own you could try jumping g term though if you wish, if it works then it would just cut some steps, if not then you just have to go back to preceeding testing the direct way.
tomorrow...
btw, dying to know why you asked:
assuming your holding ground directly on the metal top of the sending unit assembly?
I can read short from the tank, to the frame...
jumped from battery.
Found that I had to use the ground wire on the plug.
no fuel coming out of injectors however, so onto other issues.
I haven't looked at #1TDC yet since re-positioning the dist(back one tooth) & cap so that's probably pretty well outta whack.
I was hoping however, to hear it at least try & start.
Looks like maybe injector power or something...
Fuel pressure...
ECU....
More to come
Fuel pressure...
ECU....
More to come
doesnt work with just jumping the +12volts back?
did you try it with just adding the ground jumper to the fp sending unit plate, plug plugged in and just turning the key or jumpering the 12v to g on diognostic connector?
also is there a fuel pressure test port on the 84's? should be on a fuel line on the intake, any fuel there? can you check pressure there when you have pump jumpered and running?
if this is true our next test is to see if it is indead a bad ground or ground and hot wire.
this can be done a few ways,
1. is with a helper to turn the key on when you say... process is for you to go to the tank with your neg jumper from the battery in hand, meter set to dc volts, put your -neg jumper wire on the black meter probe and the red one in the fp sending unit plug coming from the car(the pin that lines up with where the fp needs the 12volts+) then have the helper turn key on to run and watch meter(you have 2 seconds to see the reading)(after that you must shut key off for at least 15 seconds to be able to get another signal from the fp relay when key is turned back on to run) if no power you need to check that the fp relay is energising(you can usually hear this or feel it when right next to the fp relay.
2. same process except you can jump your 12volt + wire to the g terminal in aldl diognostic plug under the dash then go to tank and follow above instructions.(you get all the time you need to see the voltage as this will cause it to run constant.
that should help a bit
Check with your Volt/ohm meter that the gas tank body is dead shorted to the ground wire of the fuel tank plug.
Ground wire in the plug is welded to the top of the sending unit so if the tank is grounded, the ground wire should be too...
Now, what I get is:
8.6VDC while turning ignition(first 2 seconds)
jumping to ALDL connector actuates the FP, and it does push fuel to the injectors.
I'm just guessing at this point, but considering that :
1) I farted with the FP Relay before I replaced it and COULD have shorted something in the process
2) The ECU has blackened plastic near the end of the white connector(clearly an electrical issue happened there)
I'm wondering about the ECU.
Looking at the guts of the ECU(it's apart on my workbench), there are many horrible looking components...corrosion, etc
