1991 a/c issue
Old Aug 4, 2013 | 07:07 PM
Timinva's Avatar
Timinva
Default 1991 a/c issue
I have 91 that the ac is not working. It is charged(checked with pressure gauges), but the clutch will not engage. I checked the low and high switches they both show closed. There is no power at the clutch connector even if i provide a ground. The fuse is good and has power there. I understand there is a relay somewhere but have not been able to find it. Anyone know where it is located? If I provide power to the connector with a jumper the clutch engages. Anything other than the relay to check? Thanks in advance. Tim
Old Aug 4, 2013 | 09:26 PM
SunCr's Avatar
SunCr
Disconnect and reconnect the Battery.
Old Aug 4, 2013 | 11:54 PM
Timinva's Avatar
Timinva
It looks like that fixed it, thank you. What caused this?
Again thanks compressor came right on. Tim
Old Aug 5, 2013 | 12:36 AM
Irishpilot03's Avatar
Irishpilot03
A low px code gets thrown by the ECM and prevents the compressor from cycling. Disconnecting the battery clears the codes stored in the ECM and allows the A/C switch to cycle the compressor.
To 1991 a/c issue
