Tying to do "frisbee mod" need help
Old Jun 29, 2002 | 06:06 PM
chuckster's Avatar
chuckster
Default Tying to do "frisbee mod" need help
Sounds stupid...But....
How to I keep the pully from spinning while I try to remove the bolts :confused:
Old Jun 29, 2002 | 06:37 PM
TrplBlk01's Avatar
TrplBlk01
Default Re: Tying to do "frisbee mod" need help (chuckster)
You need a helper to hold it while you get some short quick yanks on it to break the bolts loose.
Old Jun 29, 2002 | 07:16 PM
Red91Vette's Avatar
Red91Vette
Default Re: Tying to do "frisbee mod" need help (blk91)
my brother left the belt on to hold the pulley in place. then he used an air ratchet to break the bolts loose. he removed the belt after that, and took out the frisbee bolts by hand. off the frisbee came! then he reinstalled the bolts to hold on the water pump pulley, getting them finger tight. finally, he reinstalled the belt, and tightened the bolts further with the air ratchet. total time took about 5 minutes
Old Jun 30, 2002 | 12:04 AM
xzvs's Avatar
xzvs
Default Re: Tying to do "frisbee mod" need help (Red91Vette)
or put a long screwdriver over /under bolts you arent loosening and hold it that way.
Old Jun 30, 2002 | 01:50 AM
Ricks1989Roadster's Avatar
Ricks1989Roadster
I agree. The air ratchet makes the job a piece of cake.
To Tying to do "frisbee mod" need help
