Reprogramming PCM??????
Old Jun 29, 2002 | 08:29 PM
MonteSS's Avatar
MonteSS
Default Reprogramming PCM??????
Hi, I havent posted here in a while btu I have a few questions? Right now I have an 84 Monte Carlo SS. I am thinking of putting an LT1 in it. If I do this swap I will have to have the computer reprgrammed to eliminate the VATS key system, remove all the EGR junk, temp the fan kicks in, etc.
But what I dont know is this:
1. Right now I have a 700R4, but the LT1 uses the 4L60E which i know is an electronically controlled 700R4. When I have the PCM reprogrammed, can I have the company burn it so it eliminates the stuff for the 4L60E and allows me to use my regular 700R4 without a problem.
2. I saw at thuinder racing they have what they call 02 Sims. I was thinking if getting thses but they are $45 a piece. Instead of buying these when i have the computer chip burned can I have them burn it so it makes the computer think it has the o2 sensors? Thanks for any help.
Mike
My Car- http://community.webshots.com/user/mcss484
Old Jun 29, 2002 | 09:38 PM
MonteSS's Avatar
MonteSS
Default Re: Reprogramming PCM??????
The problem is the setup, is from a 95, so its PCM, I dont want to buy another computer. I would like to know if i can just work with what I have.
Old Jun 30, 2002 | 11:36 PM
MonteSS's Avatar
MonteSS
ttt
Old Jul 3, 2002 | 09:51 AM
Eric Fischer's Avatar
Eric Fischer
Default Re: Reprogramming PCM?????? (MonteSS)
I am pretty sure that the PCM is the same for either the A4 or M6, just the flash programming is different.
To Reprogramming PCM??????
