Tach wire for a 1994
Old Aug 13, 2013 | 11:56 PM
Mohammed_z's Avatar
Mohammed_z
Default Tach wire for a 1994
Does anyone how to identify the tach wire for a '94 ? I need to know that to install a shift light !
Old Aug 14, 2013 | 12:18 AM
vetteoz's Avatar
vetteoz
Where you plan hooking the tacho signal up ; in the engine bay or under the dash?
The tacho signal is a white wire going to the dash cluster connector
Old Aug 14, 2013 | 02:29 AM
Mohammed_z's Avatar
Mohammed_z
Somewhere on the dashboard.
How to reach that wire ? Do I need to remove the cluster ? or under the dash (feet area) ?
Old Aug 14, 2013 | 08:45 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Mine did not work properly hooking it up under the dash. I ran a wire to the tach filter for a better signal.
Old Aug 14, 2013 | 02:46 PM
Mohammed_z's Avatar
Mohammed_z
ok , so why it didn't work properly !! and where is the tach filter ?
Old Aug 14, 2013 | 03:08 PM
aDigitalPhantom's Avatar
aDigitalPhantom
Next to the coil.
PS
The coil is under the hood.
PPS
It has a spark wire hooked up to it going to the distributor.
PPPS
The distributor is under the water pump.
PPPPS
I will stop now.
Edit
Drinking 4+ cans of PEPSI by 1PM is not the best idea.
Old Aug 14, 2013 | 03:39 PM
Mohammed_z's Avatar
Mohammed_z
Originally Posted by chevyowner
Next to the coil.
PS
PPS
PPPS
PPPPS
I will stop now.
Edit
You really confused me lol.
I need to open my hood to check this filter , but from a quick google search I couldn't find a tach filter for a '94 !! all I saw was for a '91 or earlier !!
And it seems the filter has in&out. Where is it coming from and where does it go ? and where should I make the connection if there was a tach filter for my '94.
I'm waiting kimmer to tell me why it didn't work properly . and what year is his c4
Old Aug 14, 2013 | 03:50 PM
aDigitalPhantom
Let me try and find the one I pulled off my 93.
Old Aug 14, 2013 | 03:52 PM
kimmer's Avatar
kimmer
OK, It's a 92 and no matter what the setting on the light was it would go on around 3k. I had it connected to the white tach wire under the dash in the box. I was told to try connecting it to the tach filter so I did and it works perfectly.
Old Aug 14, 2013 | 04:00 PM
aDigitalPhantom
I was going to put off walking downstairs to try and find that tach filter, then I remembered my PEPSI is also downstairs.......going to find that PEPSI...errr....tach filter.
Mohammed_z's Avatar
Mohammed_z
Interesting , I will try under the dash first.
Old Aug 14, 2013 | 04:02 PM
Mohammed_z's Avatar
Mohammed_z
Are you sure it's a PEPSI ?
Old Aug 14, 2013 | 04:07 PM
aDigitalPhantom
I found my PEPSI
All set now.
Hers is the section of wire that goes to the coil off my car.
Old Aug 14, 2013 | 05:07 PM
Hooked on Vettes's Avatar
Hooked on Vettes
94 Corvette Vin P (LT1) did not use a tach filter.
Here's the schematic.
Signal from the ICM White wire goes to the PCM Black connector
pin B5.
Tachometer Out signal from PCM Red connector is pin A13 a White wire.
The tach wire then goes to the Electronic Brake Traction Control
Module harness. The wire also goes to C100 which is the firewall bulk head
connector where the wires from the engine compartment go
into the interior. The White tach wire then goes to the Dash Cluster
Tach.
Old Aug 14, 2013 | 05:14 PM
kimmer's Avatar
kimmer
Yup, that's where I put it but didn't work.
Old Aug 14, 2013 | 05:30 PM
aDigitalPhantom
Mitchell (OnDemand5) did no get that memo
PDF of wiring
Mitchell also thinks that a 94 zr1 wiring is the same as a 94 lt1 wiring...some how I doubt that.
Mohammed_z's Avatar
Mohammed_z
I found my PEPSI
All set now.
Thanks for the effort
pin B5.
Tach.
Great info , thanks for sharing
To Tach wire for a 1994
Old Aug 14, 2013 | 05:45 PM
aDigitalPhantom
Now i need to go and re-add that section of wiring...
Just kidding...It has a carb for now...
Old Aug 14, 2013 | 06:09 PM
pearlmom's Avatar
pearlmom
my 94 LT1 has a tach filter
Old Aug 15, 2013 | 12:59 PM
STL94LT1's Avatar
STL94LT1
This should help.
http://www.hashmarks.com/ShiftLight/
