85 knock sensor leak? Knock Block!
Old Aug 14, 2013 | 06:56 PM
xrav22's Avatar
xrav22
Default 85 knock sensor leak? Knock Block!
Hey there does anyone know if the knock sensor has coolant passing into it or is the coolant just leaking from where it is screwed in. I see a small coolant drip on the end. Anyways I went to remove it to check it out and there is a shield or something below it and mounting to the oil pan blocking me. I guess I have Knock Block! Can I remove that shield by just the 2 screws on oil pan then get to the knock sensor. Trying to forge ahead.
Old Aug 14, 2013 | 07:05 PM
vetteoz's Avatar
vetteoz
Should only have to undo the nuts leaving the studs in place
The KS is just screwed into the block.
IF you are lucky there will be a ton of crud behind it blocking the hole so you won't get drenched with coolant when you remove it to reseal
Old Aug 14, 2013 | 07:47 PM
John A. Marker's Avatar
John A. Marker
There is no passage way into the sensor for coolant. It is closed and just screws into the block. take off the two nuts and you can get to the sensor. Squeeze the electrical plug to remove it.
Old Aug 14, 2013 | 09:30 PM
WW7's Avatar
WW7
When replacing the sensor use a sensor safe sealent on the threads, and torque the sensor to the indicated foot pounds..WW
Old Aug 14, 2013 | 09:37 PM
MrWillys's Avatar
MrWillys
Why would it need to be sensor safe? Isn't that reserved for gases that will pass the O2?
I'd teflon tape it with white non hardening permatex goo.
Old Aug 14, 2013 | 09:44 PM
WW7's Avatar
WW7
If you don't use sensor safe sealant it won't allow it to ground to the block, the same with teflon tape...Knock sensor has a single wire so the ground is the block....WW
Old Aug 14, 2013 | 09:49 PM
MrWillys's Avatar
MrWillys
Good thought, I never thought of that? See, you can teach an old dog new tricks. Mine has teflon tape and works, but I must have got lucky.
Old Aug 14, 2013 | 09:51 PM
WW7's Avatar
WW7
Yep, sometimes the threads cut through the tape far enough and make contact with the block, but sometimes they don't.....It's best to only put a small amount of sealant further up the threads instead of covering them. If you leave the tip of the threads clean without sealant it will make contact at that point and you won't have any trouble......WW
Old Aug 14, 2013 | 09:52 PM
SeeFourSix's Avatar
SeeFourSix
anyone have the torque specs on the knock sensor?
Old Aug 14, 2013 | 09:55 PM
WW7's Avatar
WW7
It should be "14 ft lbs", I know thats what the 84,85,89 and the 91 cars are....WW
Old Aug 14, 2013 | 11:18 PM
desertmike1's Avatar
desertmike1
The knock sensor housing is welded to a pipe plug.. my R/H Sensor snapped off when I removed it because it was probably overtightened by some idiot.
Old Aug 15, 2013 | 01:09 AM
xrav22's Avatar
xrav22
Thx for that good to know
To 85 knock sensor leak? Knock Block!
