Problem with the AC compressor
Had a supposedly noisy bearing not very high. Thought that the bearing was dry. Disassembled the clutch from thecompressor, greased the bearing and reassembled the clutch.
No more noise.Now the clutch did not engage when putting the AC control on AC.
I have not done anything else than taking the clutch ub of the compressor and cannot find any reason than that it should be an easy task.
The AC worked before I sarted the work on it..
Any advice, recommendation and resolution of the problem will be appreciated
Earlier today, my 1992 convertible started to blow hot air when I turned on the ignition. A couple of hours of diagnostics by a skilled shop mechanic found that the wire connector to a pressure switch got corroded, and that had caused a relay to fail after a while. He cleaned up the connection, replaced the relay, and everything works just fine.
Jim G
How did you add Grease to a sealed bearing?
I have not touched the low pressure switch.
I had a tool to take off the hub, no problem with that.
Reinstalled the hub only with using the centre nut annd it went ok, but the gap is far too uge. May be about 4mm. The nut was at that gap impossible to get screwed in further.
May be I have to have an installing tool??
Many of these bearings are changed due to getting dry. With greasing them they last for a much longer time.
Its easy to take off the seal with a sharp or thin screwdriver or knife.
Underneith you see a nylon spacing device holding the alls correctly. Do not take this out just press the grease with your fingers there are enough space to let the grease enter easily. Reinstall the sealing and install the clutch hub.(where I obviously has made a mistake).
What about the low pressure switch how do I reset it? and is itnecessary to do it as I have not touched anything with the pressurized tubing.
As an apropos to greasing a bearing there is another bearing which tends to dry out and that is the serpentine belt tensioner. They can be noisy and we tend to change them. It is very easy to remove the tensioner and take a way the seal and press some greas in them and noise is gone and the bearing last for a long time after. Have not changed since after years with driving
pulley should be .38mm -.64 mm.
Here's a video that shows the process.
Thanks a million for the answers which were more than I could wish.
Tomorrow I will make an installation tool and then I hope everything will be ok.
I thought that the crank nut would be sufficient to set the clutch hub to the rigt position, but thats obvious correct.
Thanks again
AC compressor clutch replacement - YouTube
