86 intake manifold oily
Old Aug 14, 2013 | 10:38 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 86 intake manifold oily
I took off the intake manifold because of a leak in the front and noticed that the intakes for heads and inside the manifold had a thin light layer of oil on them, every cylinder. I just had the heads rebuilt and the engine cant have more than 1000 miles on it since the rebuild. I don't remember seeing this the last time I did the intake. I do have compression of about 190 in each compression test I did about a month ago. Could that cause the oil? is that normal? I didn't see any white smoke coming out the tailpipe
383 stroker
200 cc dart pro heads ported
lingenfelter intake and tpis base
58mm throttle
Old Aug 14, 2013 | 10:50 PM
John A. Marker's Avatar
John A. Marker
It is coming thru the PCV valve and then into the throttle body (passenger side of the car/TB). Hate to say it....but normal.
Old Aug 14, 2013 | 11:41 PM
PMARTINEZ92126
I just took a look at the superram box and the throttle body blades are like new. I did add some dye to the engine to diagnose an oil leak but that's all. blow by? I really hope I don't have to pull the engine. anything else I should check for?
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
It is your intake gaskets. add extra sealant on the gasket when you put it back together.
Remember, if you use sealant that smells like vinegar, it will eat holes in your intake manifold.
What not to use? the blue sealant, the gray that smells like vinegar and the black that has the same smell.
Old Aug 15, 2013 | 12:11 AM
PMARTINEZ92126
im hoping its the intake gaskets that were leaking. When I put the coolant dye in it should it was coming out of the cork gasket that was in the intake seal kit. These are the gaskets that go in the front and back. Im thinking it was leaking out of the front water jacket on the passenger side. At least im hoping. I was thinking of using Toyota black sealant. Ive used it before and it sealed nicely. I didn't use much sealant and was relying on the thin blue sealant that was manufactured on the intake gasket itself
Old Aug 15, 2013 | 09:53 AM
coupeguy2001
Remember, the intake passages on the manifold are oil on one side and vacuum on the other. if there is a slight mis match in machining, the intake gasket gets pinched on one side, and the other side is a little loose. With hot and cold cycling of the engine, the gaskets squeeze and then get unsqueezed, and the looser side of the gasket will eventually compress, and the oil will find a way into the intake. Since oil creeps, it will find it's way up a little ways, but most always be heavier in the head port.
Old Aug 15, 2013 | 11:38 AM
PMARTINEZ92126
what have you guys been using for sealant? i have a little minor minor corrosion around the water jackets.
Old Aug 19, 2013 | 12:36 AM
coupeguy2001
Go to autozone, and buy a can of "the right stuff". It is the correct sealant to use.
Old Aug 19, 2013 | 03:08 AM
Cliff Harris's Avatar
Cliff Harris
I bought a Fel-Pro intake gasket set and it did not come with end gaskets. There was a tube of RTV sealer in the box.
The "vinegar smell" is acetic acid. It is used as an inhibitor to keep the RTV from curing. The RTV cures when the acetic acid evaporates. That was old technology and the newer versions of RTV use a different inhibitor that doesn't smell so bad. Look for "oxygen sensor safe" RTV, as the wrong kind can poison your O2 sensor.
Old Aug 19, 2013 | 02:12 PM
383vett's Avatar
383vett
When I was running a SuperRam (10+ years), I did not run a pcv. Still there was oil in the runners. The reversion from these long runner intake systems is pretty amazing. Depending on camshaft overlap, combustion poo is pulled into the runners resulting in an oily film. My motors did not burn oil, but still upon disassembly of the intakes, there was always a puddle of oil in each runner. This happened on different motors with different rebuilds every time. I wouldn't worry about it.
Old Aug 19, 2013 | 04:39 PM
1993 Z07's Avatar
1993 Z07
I agree 100% with 383 Vett. He knows exactly what the issue is, reversion. On the silicone Honda Bond is the best but expensive. The grey permatex works almost as well. I have had leaks with the blue I would never use it. The grey beats the black.
To 86 intake manifold oily
