C4 No Flex Frame Stiffener Bar System
It works as advertised!...
http://forums.corvetteforum.com/c4-g...me-braces.html
http://forums.corvetteforum.com/c4-t...s-stiffer.html
The only problem was it is hard to install because most vehicles that aren't convertibles don't have the rear holes for mounting drilled and threaded. I measured it incorrectly and messed up the hole locations so I'll have to have some work done to get it right, probably get a plate welded in to do it right. Currently it's sitting leaned up against the wall in my garage but I miss having it installed.
IIRC, they provided nutserts for the holes that had to be drilled in the coupe frame. I think that the RD brace also hung down a good inch or so below the frame compared to the factory brace.
Finding and installing a factory brace would work work but the rear mounting holes would still have to be drilled and nutserts added. The center portion of the brace can be bolted to the floorpan simply by drilling holes and using bolts and nuts. The OEM brace can easily be boxed using some pieces of steel flat stock and welded to the brace.
Yeah, it did hang down about 1.5" so on a lowered car they would be a problem, even on a stock height vehicle I dragged it over speed bumps on occasion.
That was a huge improvement over the R/D system in rigidity and less squeaks .
On my convertible I boxed in the factory cross brace and run the factory hardtop when doing an auto cross . So the convertible is pretty good for a C 4
The setup is a bit heavy but its right in the middle of the car and right at the bottom which I think is the best place really to add any weight if you had to. I'm not happy about the camber brace adding weight on the nose but I will be getting one of those when I can find one for the lt5.
To those that added one.. Did you tighten or extend the bars to get the stiffness you wanted? Instructions are vague so I was curious which way people found had the most impact. Hopefully ill get to install it tonight and ill make a thread with pics of the install.
The guy that designed this is in the NCM Hall of Fame. If you have ever been to one of his seminars you will remember that he is a genius.
(OTOH...profit = margin x units sold. Hmmm.... I see they originally planned to sell this sucker for $700ish. Really?)Seriously, I see how it would help -- assuming the stock frame rails really flex as much as the product description implies. By attaching to a second point on the frame and tensioning that bar, the fore/aft can't flex "upward" (or downward) as much. The bar just looks SO flimsy in respect to the frame.
Based on the ability to reduce windshield-to-BPillar flex when jacked, that's how I see the car must actually flex "longitudally" as described in a linked thread. (And, that person said he wouldn't drive a C4 if it flexed like that. But, it must -- if the windshield/BPillar gap increases when jacked between the wheels!)
I actually question whether an x-brace would do less -- as one person suggests because it's accomplishing the same function. Strength of materials involved would affect the outcome though...and I gotta think tubular steel is stronger than flat-steel. That's must be the reason.
I might have to suggest this to RPP_Corvette for consideration.
