The “MegaRam” Ported FIRST (FFI) Intake
I’m fully porting the base and siamesing the runners and plenum of the FIRST intake. The base intake porting is done, except for the final clean-up and port alignment for the head and runner openings. Top half of the picture below shows the ported FIRST base (Felpro 1207) on top of an unported FIRST. Bottom half shows the inlet side of the ported FIRST base. I haven’t touched the as cast opening yet – it is right at 1.85” ID so it won’t take much to finish it to the planned 1.9” ID. Pictures really do not do this thing justice,,, it looks more like a big-block intake in person – especially after the porting!
I wanted to siamese the runners on the FIRST, but the creases in the runners will only allow you to “notch” siamese the runners (similar to how the SLP TPI runners come out of the box).
Here’s a picture of where gbayfisher at TGO “siamese” notched the FIRST runners about 2” for his AFR383 build.
While notching the runners will add a few hundred RPM to the FIRST, I wanted to fully siamese the runners to about the halfway point. I expect this to shift the power band up about 500rpm and make peak HP around 5800rpm (6200rpm shift-point). So, I had the center creases of the runners welded where I could fully flatten the floor. Here’s a picture of the front and back welds - I threw in a fully ported FIRST runner (1.92” ID) to reference how large the bottom openings will end up being.
Here she is mocked up with the welded runners. There was some concern that the runners might warp,, but everything fit, sealed, and lined up perfectly. The plan is to blend in the welds and paint the runners with a black epoxy or crinkle paint for a bit of a stealth look.
Before people ask, I fully understand that the short/shorter runners have the potential of running faster when properly cammed, geared, and stalled. I’ve been there done that,, leaning more towards racing than driving and hated it. This is going in a relatively heavy 3650lb race weight car running 3.55 gears and a 3200 rpm converter – which tend to be less than optimal for most combinations utilizing a short runner intake. Still,, I have no doubt that I’m giving up a little ET and more than a couple MPH. However, I’m not going to be at the track much this time around and I’m more than willing to give up a little ET to get the considerable, tuned midrange boost for “cruising around”. Plus,, the TPI was designed for a 305,,, right???
Stay tuned for pictures of the siamesed ported runners and plenum. It may take a while,, I’m finishing up the 4,,, uh,,, I mean 305 engine this coming week.
While the FIRST will cover a 1207 port without welding material to the intake flange,,,, I had to get a little extra material welded to the top of the flange because of the "semi-raised ports. I had to have that done to the last intake I was running as well, a Brodix HVH single plane. Here’s a shot of the intake flange - left side after welding,,, right side after smoothing things out and blending it in.
Was just helping a friend tune it on a zz4 engine-the injectors were sticking open most of the time.
Looked up the part number-they were used on 2005/6 ford f150 and up, 24lbs and were recalled......
I've been lucky in the past and haven't had to pull an intake. Part of that came from using pop up roller lifters,, that and a two-piece timing chain cover made cam swaps a cake walk. I'm using pressure fed roller lifters this time,,, so I hope the cam pick is right - lol.
I do like that "TPI" plenum on the single plane,, that took a bit of work in itself.
Here’s step one completed on the first pair of runners. I knew it was going to take some time,, but man,,, these runner have a ton of meat to remove.
Specially with TPI stuff the runners are so long to make any difference you really have to dig in more than one would think. Its a buttload of time for sure. Not fun
Been helping a friend try to sort out the full kit he bought from them with 730 ecm and prom.
The injectors were recalled in 2007, used in 2005 f150/250 fords. They were sticking open dumping fuel. The 8d program they supplied-not even close.
When he called them they said so sorry, but it's out of warranty-he hasn't even been able to make it do more than stumble over idle since he bought it last year.
Yup the intake looks good, however I'm not at all impressed with the "full kit". So if anyone is thinking of it as a bolt on and go think again.....
