1985 airpump delete help
Old Aug 19, 2013 | 08:14 PM
nickpe's Avatar
nickpe
Default 1985 airpump delete help
Hi guy's, I'm looking t remove my air pump. What make is a good air pump delete. Has anyone eliminated the pully and used a smaller belt. What options do I have. I'm installing headers and removing cats.
As always thanks for helping
Nick
Old Aug 19, 2013 | 10:16 PM
WW7's Avatar
WW7
I have the TPIS air pump delete on my 89...Around $160.00 but it's well made and cleans up the engine bay a little...WW
http://www.tpis.com/parts/view/62
Old Aug 19, 2013 | 10:31 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check out the one from Corvettemods1 here. He is a Forum vendor and has excellent service
Old Aug 20, 2013 | 04:52 AM
hemivett's Avatar
hemivett
I was able to remove mine, and take as much apart as I could, then I beat the guts out with a big hammer, and screwdriver. (Til it was a pulley held by the case) Then put it back together, and put it back on. Now its just a pulley, and I kept the same belt. Not pretty like some, but much cheaper. $0 h
Old Aug 20, 2013 | 11:37 PM
gerardvg's Avatar
gerardvg
That is what i used for a few years, until i realized a bigger air pump is better.
Old Sep 13, 2013 | 08:00 PM
Benjikittens's Avatar
Benjikittens
what brand super charger
Old Sep 14, 2013 | 11:58 AM
bob guzzy's Avatar
bob guzzy
If you are going to delete your smog pump and it still working I swap my delete kit for your whole setup.
This one was just installed on my car before I got it, I would rather have a stock looking engine
BTW the stock belt works no need to down size on the belt, my belt tensioner was weak when I got the car, the tensioner caused all kinds of belt slippage, I tried an undersized belt it did nothing to help.
The tensioner was 30 bucks or so on amamzon
Old Sep 14, 2013 | 07:17 PM
HlhnEast's Avatar
HlhnEast
Darn Aussies, steering wheel on the wrong side, backwards azzed alternators, puttin vacuum cleaners under the hood. I just dont know what to think
mate!
Old Sep 15, 2013 | 03:16 AM
DHobbs's Avatar
DHobbs
Know this. On my 85, I've had it deleted for 2 years now and I lost all the alternator housing bolts + alternator and the connector because I didnt make a bracket for the back of the alternator. It shook the bolts out fro. Driving and all broke. Just make sure you have something to brace the back of it if you put this on
Old Sep 15, 2013 | 04:40 AM
floridamale's Avatar
floridamale
There should be a brace already that attaches the alternator to the exhaust manifold which would be part of the stock set-up
Old Sep 15, 2013 | 09:30 AM
HlhnEast's Avatar
HlhnEast
All the braces should be kept in stock locations. A PO may have chucked the braces after an alternator or header install thinking it isnt a big deal. You get hardware to put these brackets back with a quality set of headers because they thought the braces were important.
Check at some Vette junk yards for replacements or make some braces.
Old Sep 15, 2013 | 10:03 PM
DHobbs's Avatar
DHobbs
I bought mine new and it relocated the alternator farther to the outside. I fabbed up a brace but the stock one wouldnt reach
Old Sep 16, 2013 | 05:33 AM
cohocarl's Avatar
cohocarl
Depending on how far you want to go with your delete, here's a link to a couple different options
Air pump delete
Old Nov 2, 2013 | 06:55 PM
davesabo's Avatar
davesabo
hey does removing the air pump throw any codes? im not to worried about passing inspection but i dont want ECM issues and check engine lights please let me know what to expect thanks for the time.
Old Nov 2, 2013 | 07:03 PM
vetteoz's Avatar
vetteoz
No ,
there is no feedback to the ECM
Old Nov 3, 2013 | 05:54 PM
davesabo's Avatar
davesabo
thanks vette oz im still working on my heat door.. waiting for a Friend to come help me jump the motor wires to see if the door moves hopefully it does and if so i will remove and repair the black programmer and get that repaired i suck at electric stuff..
did a new coolant temp sensor still takes 6-8 cranks to fire.
other wise runs well - thanks for all the info tho.
To 1985 airpump delete help
