Need RSD Line Lock Instructions
Old Aug 19, 2013 | 10:47 PM
Fastime's Avatar
Fastime
Default Need RSD Line Lock Instructions
A few months ago I purchased a used RSD Line Lock from a Forum member but I didn't receive the instructions, does anyone still have them?
Old Aug 19, 2013 | 11:46 PM
vetteoz's Avatar
vetteoz
Tried a PM to RSD , a CF supporting vendor
Steve@RSD was on CF last week
http://forums.corvetteforum.com/1577115253-post82.html
Old Aug 20, 2013 | 09:47 AM
Fastime's Avatar
Fastime
Thank you
Old Aug 21, 2013 | 09:24 AM
Fastime's Avatar
Fastime
Still looking for some help.
Old Aug 22, 2013 | 04:38 PM
Fastime's Avatar
Fastime
Someone must have installed this unit
Old Aug 22, 2013 | 06:00 PM
383vett's Avatar
383vett
How is this unit different than any other line lock except prevent tubing. One wire to 12 volts. One to ground and intercept the front brake line out of the master cylinder
Old Aug 22, 2013 | 09:18 PM
Fastime's Avatar
Fastime
I guess I should have given more info, the problem is not electrical but hydraulic. The line lock unit has one line in and one line out and it looks like the master cylinder has two lines going to the front brakes and one to the rear. Not sure how to plump the lines.
Old Aug 22, 2013 | 10:53 PM
383vett's Avatar
383vett
Have the two lines T into 1 going into the linelock. Split them back into 2 after the linelock
Old Aug 23, 2013 | 01:00 AM
vetteoz's Avatar
vetteoz
Originally Posted by Fastime
I should have given more info ...........
If you had mentioned up front you were working on a 85 with the dual front lines it would have helped.
Has been well documented on here
http://forums.corvetteforum.com/c4-g...with-pics.html
http://s8.photobucket.com/user/vet85...?sort=4&page=1
Old Aug 23, 2013 | 08:41 AM
Fastime's Avatar
Fastime
Thank you very much for the help, I did not realize the 84 to 85 Master Cylinder was different until last night. Off to the parts store.
To Need RSD Line Lock Instructions
