-=Please Help - Looking for a DFI Global File - 383 SuperRam=-
I really need some help getting my DFI Programed! I first fired up my combo last year and my injectors were way to big (48lb) I also burnt thru a plug wire and the aftermath was a pan full of oil and gas, which led to a spun bearing or two. I don't want to do that again!!!
I have gotten the motor rebuilt, and this time I am using FMS 30lb Injectors!!
Here are my specs:
383 - Eagle Steel Crank
Eagle H-Beam Rods
SRP Forged pistons 9:1
AFR 190 heads 2.02/1.60
Comp Cams Roller Lifters
Comp Cams Roller Rockers
Crane Hyd. Roller Camshaft 222/230 Duration .509/.528 Lift 112 Lobe
SuperRam
Ling. 58mm TB
1 Bar Map
700R4 2600 Stall Non-Lockup
1 5/8" --> 3" headers --> Dual 2 1/2" --> Flowmaster 40's
I am running 40psi Fuel Pressure
I am looking for a Global File I can use to get this thing going. I used the utility to make a base fuel map, it seems to run ok, but I'm wondering if anyone has one I can take a peek at!
Any feedback would be great!!!
Bill
