Idle success!
Old Aug 26, 2013 | 09:38 PM
TBSS/85vette's Avatar
TBSS/85vette
Default Idle success!
It took me awhile and now for the first time in years there is no idle loping and inevitable cutoff at stop. I have a perfect, steady idle now. There was a big vacumn leak where the PCV extension pipe goes into the manifold. There is a soft rubber gasket/tube that the pipe goes into that basically after 28 years of heat looks like a floppy vagina and no longer seals well. I put a small zip tie around it and went for a drive tonight. I now have a perfect steady idle. I drove it on Saturday and it cut out at every stop if I did not press the accelerator a little bit, been like that for years. In all of my searching I never found this solution. Does anybody know what that part is called and is it available?
Old Aug 26, 2013 | 09:42 PM
John A. Marker's Avatar
John A. Marker
Just replace it with a new section of hose.
Old Aug 27, 2013 | 04:24 AM
Cliff Harris's Avatar
Cliff Harris
I had that same problem after that rubber hose dried out and split. The original hose was glued to the PCV tube. I put some random hose I had on hand on there and a few years later I had a rough idle when the engine was hot. I found the problem because the hose made a high pitched hissing noise (but only when hot). Fixed by zip tie.
My parts book shows the hose and tube as an assembly (one part number). It's called a "Pipe, crankcase vent valve".
To Idle success!
