flushing brakelines?
Old Aug 27, 2013 | 08:14 AM
dave73's Avatar
dave73
Default flushing brakelines?
Hi all,
I got a 89 that I'm restoring, I'm doing brakes rite now... Question is, is it worth or should I take the time to flush all brake fluid from lines and parts? Do you feel this is something that should be done or not...also, any tricks for this? Thanks all...good day!!!
Old Aug 27, 2013 | 08:22 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by dave73
Hi all,
Have you replaced the brake hoses? You mention "restore"! There's many reasons to both replace the brake hoses due to age and the flush of the entire system is also I'd think a should do. Avoid all of the higher tech fluids and use proper spec'd fluid for the times. Restore is a "stretch" sometimes in what is actually being done to any vehicle.
Old Aug 27, 2013 | 09:26 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Yes, do it. "Flushing" is really just bleeding the brakes until all the fluid runs clear. Should be done every couple of years.
Old Aug 27, 2013 | 09:38 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
If your in no hurry [ like me] do a gravity bleed.
Old Aug 27, 2013 | 10:14 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
X2.
One person deal...easy.
If you want to expedite a one person flush;
*open all the bleeders. set up proper catch buckets, and then pump the brake pedal...while closely monitoring fluid level in the reservoir. Obviously, don't let the reservoir run dry. Anyway, pumping the pedal pushing the new/clean fluid through the system very fast.
*After maybe 4 pumps, go see which calipers are draining clear fluid, and close them.
*Pump the pedal a couple more times, check again. If there are any calipers that are NOT dripping clean fluid, close the rest and pump again.
*after you have forced clear fluid through them all, go back and open them all to let the air out that gets drawn into the caliper when releasing the pedal. Tapping on the caliper body with a hammer helps bubbles break free of surface tension and float to the top and out the bleeder.
*Start with the caliper that is flowing the most and work toward the one that is flowing the least. When no more bubbles are coming out, you're done.
Process usually takes about 10 minutes and requires no special tools or extra helpers.
Old Aug 27, 2013 | 10:20 AM
c4cruiser's Avatar
c4cruiser
Definitely flush the old fluid out and use a good quality DOT3 brake fluid and replace the flex hoses at the wheels. You can find fluids like Valvoline SynPower and Castrol LMA at parts stores and another good choice is the Ford Motorsports HD fluid. It will take about 3 pints to do a complete flush and refill of the system.
The ABS system has its own bleed valve to flush the fluid in that, but it can be a messy job. It's in the compartment behind the driver's seat. Do you have a FSM for your car? You will find good detailed explanations for flushing the ABS in there.
To flushing brakelines?
