a little advice please!!
Old Aug 27, 2013 | 04:53 PM
playsdixie's Avatar
playsdixie
Default a little advice please!!
getting ready to call jon regarding the bosch3 injectors for my 85..while i've got it torn down, 117,000...I'm going to change the egr and fpr....i've been looking at the adjustable, seems to be a great variance in prices....and if i understand it right, they don't include the diapragm and spring...looks like tpis has a good one, but i'll have to get the diapragm separately right???...
also, i don't want to get carried away with mods, but one of the runners has a slight ding in it,,,,i see they have bigger/better fuel runners....are they worth the 400 bucks?..
lastly, is there anything else I should consider changing while it's stripped down?? I'm a working stiff, but i'll get what I need to make it right....pushing retirement back now.....
Old Aug 27, 2013 | 05:22 PM
hooked073's Avatar
hooked073
you may gain a little if you change runners but not much on a stock engine. So my answer to that would be no. I also do not think a agj FPR is need for what you are doing. I would check everthing you can see now while it is apart hoses conections ect. If the stat has not been changed I would change it and the upper hose if not new. just a real good look over
Old Aug 27, 2013 | 05:26 PM
MrWillys's Avatar
MrWillys
Sometimes you can push a ball down through the runner to straighten out the dent. Can't remember the size? TPIS is the best adjustable cap in my opinion. I wouldn't replace the diaphragm until it goes bad. Why take a good USA product and replace with lesser quality.
Honestly, I'd just buy Jon's 280-155-715 Ford blue's as direct replacements. They're just slightly bigger than stock and work with without an adjustable cap on the 85.
Old Aug 27, 2013 | 06:24 PM
playsdixie's Avatar
playsdixie
good advice..a bit cheaper too....thanks
Old Aug 27, 2013 | 10:13 PM
leesvet's Avatar
leesvet
If you want to make a positive difference and upgrade, start with the exhaust and you WILL feel a difference and establish a base for other mods down the road. There is nothing that can be done to help the stock engine until the exhaust is fixed....that is the single biggest problem the stock engine has. NEXT would be the runners and intake. No point in feeding it until it has an exit....
Old Aug 27, 2013 | 10:58 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Unless you have a huge budget you would best served by doing a good tuneup and making sure the car is running good before doing any mods. Plugs, wires, cap, rotor etc. Then flush and refill the fluids and clean out the junk that is lodged between your radiator and ac condenser.
The TPI unit is restrictive and so is the exhaust. In order to get a performance boost you need better cam, heads,ignition, intake and exhaust along with rocker arms etc. It gets expensive.
Do a Google search for Vader86 as he has a nice website about the "Dark Side" that will tell you what works and what does not.
Old Aug 28, 2013 | 12:03 AM
gerardvg's Avatar
gerardvg
Good long tube headers will knock around half a second of your quarter mile time, Yes replace the fuel pump diaphragm this is critical if the diaghragm tears or splits it will send fuel at pressure thru the vacuum hose to the engine. If the tear is big enough it can force the vacuum hose of the fuel pressure regulator and spray fuel onto your exhaust..
You can modify your stock fuel pressure regulator, when its disassembled drill a small hole in the top cover and tap a thread then insert a screw with a spring to stop it moving. TPI's love more fuel pressure 45 psi is a sweet spot, however if you need emissions testing it can fail with rich idle so set back to standard pressure beforehand.
Remember with Bosch 111 injectors use two O rings at the bottom and one on top of each injector, the bosch injectors are small and do not rest on the manifold like standard ones. The fuel pressure can force the injector down causing a leak at the fuel rail / injector.
Old Aug 28, 2013 | 05:34 AM
blackozvet's Avatar
blackozvet
the Bosch 3 24 lb injectors from Jon work well in the '85 and will freshen things up,
i got an anodized adjustable reg and new diaphragm from south bay fuel injectors, $70 for both, but if you get an adjustable reg you will also have to buy a fuel pressure gauge to be able to adjust it,
I wouldnt worry about the runner upgrade till you have more mods, as the other guys have stated, the exhaust is a better place to start.
Old Aug 28, 2013 | 09:24 AM
leesvet's Avatar
leesvet
[QUOTE=gerardvg;1584779585]
Had it happen ! mine was due to a shorted injector that caused that bank to be stuck WFO....
Battled the engine (no start) all morning and it finally fired...
I had to force-feed it throttle to keep it running when I saw the LIQUID BLOWING out the exhaust pipes....got out to see WTF and realized it was RAW GAS ! We were IN my garage so the fumes were thick enough to swim in...nice! Gonna loose my CAR and house together...good job !
I haven't had a panic attack like that since I had 2 UC detectives pull me over with their guns drawn....( caused I passed them at 100mph on a public street in Ca)
Must have been 2 gal in the pan, and God knows how much in the exhaust. Took me days to get it cleaned up and around 4 or 5 oil changes.
Old Aug 28, 2013 | 02:53 PM
playsdixie's Avatar
playsdixie
your advice is great....so you all know.....I have changed the radiator, new plugs /wires/cap/ rotor/ exhaust has been worked on, installed muffler eliminators/ going to put the x pipe on next....had it running really smooth, but now all of a sudden, a little rough idle has occurred, almost sounds like it's missing a little at idle....going to check the timing, but since I have 100,000 + miles, I figured a new set of injectors, and egr may solve it anyway....put the vortex rammer in it,..for more air....kinda cheesy, but it seems like it works ok....idle for some reason is low, 540/550/ rpm....was running soothly at 600..runs too crappy at idle to reset it per the fsm...checked tps...54v ..I figured with the rammer and exhaust, bigger runners might help some...don't want to get too far away from stock... i'd prefer it was running great before I tore it down but whatever......
Old Aug 29, 2013 | 02:22 AM
Cliff Harris's Avatar
Cliff Harris
Had it happen !
Those symptoms are painfully familiar. I went out to lunch at my favorite restaurant and when I tried to start the car it didn't want to run. I kept cranking it until I noticed smoke coming out from the back of the hood and coming up in front of the windshield. Then I saw FLAMES there. I got out of the car and opened the hood and there were flames coming out from under both sides of the plenum. The whole top of the intake manifold was a lake of burning fuel, which was running off the front and back and there was a puddle of burning fuel under the car. Fortunately I had a fire extinguisher from the days when I used to autocross this car...
Ruptured fuel pressure regulator diaphragm:
Old Aug 29, 2013 | 04:55 PM
playsdixie's Avatar
playsdixie
I'm convinced....i'll get a tpis adjustable and change the diaphragm too....in my line of work, murphy's law is absolute...
Old Aug 31, 2013 | 12:12 PM
playsdixie's Avatar
playsdixie
are those injectors 24#...?? I thought stock was 22.....if I use them, do I have to reprogram the ecm?
Old Aug 31, 2013 | 12:49 PM
856SPEED's Avatar
856SPEED
I think so; I know you don't need 24's on a stock 85; I am running 24's with an adjustable fuel pressure reg. but I am far from stock and the 24 Bosch's work great on mine; I would say 22's would work just fine on a stock 85, no problem.
Old Aug 31, 2013 | 03:57 PM
John A. Marker's Avatar
John A. Marker
The stock/standard injectors for the 85 were 24#. You can check with Jon at FIC.
The adjustable FPR should come with the diaphragm. You should not have to buy a new one.
Old Aug 31, 2013 | 04:05 PM
MrWillys's Avatar
MrWillys
GM used a Bosch 280-150-223 which is 23.8 lbs rated at 3 Bar or 43.5 psi. They installed them with a regulator at 39 psi, so they programmed them at 22.4 lbs. This lower pressure resulted in the lower output. If you buy Jon's Bosch III 280-155-715 it's rated at 24.3 bs at 43.5 psi. Therefore, you'll be getting a slight increase and won't need the adjustable cap, or diaphragm. Why fix something that ain't broke just cause it broke on someone else? Preventative with certain things is fine, but why rebuild your engine if it runs fine?
http://www.witchhunter.com/flowdatapix/b0280150223.jpg
252 cc is 24 lbs
http://www.witchhunter.com/flowdatapix/b0280155715.jpg
This is what Jon's flow.
Scott
Old Sep 1, 2013 | 10:59 AM
playsdixie's Avatar
playsdixie
252 cc is 24 lbs
Scott
won't I need the adjustable reg to get 43.5 psi???..i'm confused?...sorry for being slow...didn't see anybody selling adjustable regs that came with the spring and diaphragm....
Old Sep 1, 2013 | 11:58 AM
MrWillys's Avatar
MrWillys
Maybe this calculator will help you understand:
http://www.csgnetwork.com/fiflowcalc.html
Basically, injectors are rated at 43.5 psi (3 bar), but if installed at a lower pressure they flow less. I entered the 24.3 lb in the calculator with a new pressure of 39 psi and it came up with 23 lbs. This would be a slight increase over stock. If you put on an adjustable cap, and bumped pressure up to 43.5 you would have 24.3 lbs, and would need reprogramming.
Old Sep 1, 2013 | 02:03 PM
playsdixie's Avatar
playsdixie
got it...thanks....i'd like to stay away from any programming issues...running nicely would be just fine......love the car but think computers make great boat anchors....
To a little advice please!!
