A quick injector question
Old Jul 1, 2002 | 10:19 AM
ittlfly's Avatar
ittlfly
Default A quick injector question
What would be the ohm's on a new stock injector for a 92 LT-1? I checked all mine and they showed the ohms between 12.4 and 12.7. I was wondering if these figures are OK.
Thanks in advance for the help.
Old Jul 1, 2002 | 10:48 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: A quick injector question (ittlfly)
Those are good values; an important feature is that all readings are close.
They may still benefit from a cleaning but at least the coil windings are ok.
Old Jul 1, 2002 | 11:51 AM
ittlfly's Avatar
ittlfly
Default Re: A quick injector question (65Z01)
Thanks for the reply. I wasn't sure as the Helms doesn't give a value for new injectors for comparison. They just say to replace if they don't measure better than 10 ohms.
[Modified by ittlfly, 7:52 AM 7/1/2002]
[Modified by ittlfly, 7:54 AM 7/1/2002]
Old Jul 1, 2002 | 11:59 AM
65Z01's Avatar
65Z01
I remember reading that the L98 injectors should typically give values in the 12-15 Ohm range and think yours are similar.
To A quick injector question
