Change Trans. Fluid.....Yes or No
Old Jul 1, 2002 | 11:43 AM
champs_97's Avatar
champs_97
Default Change Trans. Fluid.....Yes or No
I've read here that it's a good thing to change all fluids when you first aquire a new car and I agree, but I have also heard that changing the tranny fluid is not really recomended for cars with higher mileage and that it can actually induce problems especially if you flush. My car has 79,000 miles on it and it is an 85' L98. Any thoughts?
Old Jul 1, 2002 | 11:50 AM
pzoom's Avatar
pzoom
Default Re: Change Trans. Fluid.....Yes or No (champs_97)
Yea, I have been wondering the same thing too. I was thinking about just draining and adding. Maybe do this every year instead of a complete flush. I have 124K miles.....
Old Jul 1, 2002 | 11:57 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Here is my take:
Bought the car in 2001 with 117k on the clock
In Jan of 2002 replaced all the fluids because I had no clue as to the maintenance done before (120K)
At the time of the full change the car seemed happier with the fresh fluids (including synthetic motor oil).
I now have 128K and have experienced no transmission or differential problems. I'm sticking with synthetic motor oil (Mobil 1) because it doesn't leak any more than it did with dino oil. It seems to run better with the synthetic.
JMHO
Old Jul 1, 2002 | 12:02 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I dont flush the tranny but simply drop the pan,let it drain,replace filter,fill back up etc.
Doing this now will also allow you to see if theres any metal shavings/shrapnel in the pan or burnt fluid.
If so,the tranny will go eventually.
It should not hurt anything to change the fluids.In my cases,it made the tranny shift better and run good again.I have heard the stories about people replacing the fluid/filter then afterwards the tranny went boom.I still think it was on its way out eventually.
Old Jul 1, 2002 | 12:10 PM
silver & red CE's Avatar
silver & red CE
Default Re: Change Trans. Fluid.....Yes or No (Bill's86Coupe)
I think this is the source of the old wives tale, you should never change the fluid if there's lot's of miles on the trans with original fluid. If the car went over 100k miles on the original fluid, it's hard to imagine the previous owner gave very good care to the car. If that's the case, why be surprised when the trans goes? IMHO, if your trans is in good shape, a fluid change will be fine, if your trans is on it's way out, a fluid change isn't going to do much to help or hurt the situation.
Eric
Old Jul 1, 2002 | 12:30 PM
OleDog's Avatar
OleDog
Default Re: Change Trans. Fluid.....Yes or No (silver & red CE)
I agree with Siler&Red. I flushed mine by taking the upper trans fitting off, connecting a hose and clamp to the line, putting the hose into an empty laundry detergent container(holds about 2 1/2 Gals.) Opened 12 Quarts of Dextron III . Started the car as it pumped out I poured in. By the time I got to the 11th quart the fluid coming out was clean and red. Shut it off ,reconnected the line. Topped it off. Later I will change the trans gasket and filter. That should only be around 4 quarts or so.
Old Jul 1, 2002 | 01:35 PM
J Z06's Avatar
J Z06
:yesnod: On the money Bill! :)
Old Jul 1, 2002 | 11:22 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
You shouldn't have any problems when you change your trans fluid (stay away from the flushing agents). I changed mine when I bought my '85 with 111,000 miles on it. I've had no problems and no leaks. When in doubt, change it out! :yesnod:
Old Jul 1, 2002 | 11:30 PM
MrNuke's Avatar
MrNuke
Default Re: Change Trans. Fluid.....Yes or No (H P Bushrod)
I had mine changed at 70K, 90K and just now at 103K.. No problems (knock on wood).
Every time I had the shop drop the pan and check for metal shavings. Nothing.. :smash:
Old Jul 2, 2002 | 01:16 AM
Justin1984's Avatar
Justin1984
what is everybody here running in their 700R4's?
Old Jul 2, 2002 | 06:25 AM
93 ragtop's Avatar
93 ragtop
Default Re: Change Trans. Fluid.....Yes or No (Justin1984)
I have a good friend who has worked on a bench rebuilding transmissions for 25 + years. He believes that as long as you change the filter a flush will not hurt anything. However he also says its not necessary. Just change the filter and the 4 or 5 qts of fluid every 15,000 miles and enough of the fluid will be changed.
Old Jul 2, 2002 | 11:11 AM
silver & red CE
I run Mobil1 in my 4L60E (same thing as a 700R4, just control electronically).
Eric
Old Jul 2, 2002 | 11:32 AM
ParadiseSD's Avatar
ParadiseSD
Default Re: Change Trans. Fluid.....Yes or No (OleDog)
This is very creative!! :cool:
Old Jul 2, 2002 | 05:57 PM
dppeaden's Avatar
dppeaden
Do you change your Oil? Then Change the trans fluid and the filter. It ia also a good idea to change the rear end grease as well. If you use a syn you can even pick up a couple of HP. (As stated by Popular HotRoading TV).
Old Jul 2, 2002 | 07:28 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
just do it! :yesnod: :cheers:
Old Jul 3, 2002 | 02:28 AM
Dutch W.'s Avatar
Dutch W.
Default Re: Change Trans. Fluid.....Yes or No (yoslambo1@cs.com)
I was reading the other day in a magazine (Corvette Fever, I think) where the writer thought this should be changed every 2 years regardless of miles due to condensation/water.
Any consensus out there as to whether 2 years is about right or if its really the mileage that counts?
For what it is worth, I was told by someone that 12,000 mi is about the right interval....
Old Jul 3, 2002 | 03:51 AM
Bob Mosaic's Avatar
Bob Mosaic
Default Re: Change Trans. Fluid.....Yes or No (Dutch W.)
My experience along with the experience of friends in the tranny biz all agree that tranny fluid is very fickle....If the fluid is old crap than you should leave it old and crappy. If it looks and SMELLS fair, but in need of a change you may be OK. Old crappy fluid being replaced partially by the 4 qts. in the pan will turn the remaining 7.5 qts. into a solvent that will induce a quick wear to the clutch faces. 12k is the best change interval for a tranny. Fluid that has a 100k or so on it no longer has the same properties of new fluid and they don't mix with benefitial results. How does your fluid look? smell? miles?
Also, the enemy of any auto tranny is heat, old fluid does not dissapate heat very well. Thus causing wear to occur at a much higher rate.
Just MHO.
Good luck,
Robert
To Change Trans. Fluid.....Yes or No
