1991 L98 Vapor / Charcoal Canister Location
Old 08-31-2013, 09:38 AM
SeeFourSix
SeeFourSix's Avatar
Default 1991 L98 Vapor / Charcoal Canister Location
Where is this thing on a 91? I looked at the front by the headlights and at the rear quarter panels and dont see it through the fuel door hole (removed). I assume it's at the rear somewhere? How should I access it to replace it?
Old 08-31-2013, 09:48 AM
666Vette91
666Vette91's Avatar
Located behind the left (pass side) rear tire, just remove both tire and wheel well. It is a little tricky to remove, just be patient you can.
Old 08-31-2013, 09:59 AM
SeeFourSix
SeeFourSix's Avatar
Sweet thanks. I looked there through the fuel door hole (it's removed) but it must be out of sight from that angle. Just to clarify, by left (pass side) you do mean the curbside (not roadside) correct? I usually associate left with driver side.
Nilak (11-04-2021)
Old 09-08-2013, 09:02 PM
666Vette91
666Vette91's Avatar
Back on line today, correct, back passenger side. You won't see it through the open gas door, too far down. Just remove wheel well if you haven't already.
To 1991 L98 Vapor / Charcoal Canister Location
Quick Reply: 1991 L98 Vapor / Charcoal Canister Location
