c4 auto transmission shifting
Old Aug 31, 2013 | 09:20 PM
rangerman55's Avatar
rangerman55
Default c4 auto transmission shifting
I have seen some threads on here a while back about this problem, but need some help with my auto tranny. In talking to some Vette owners in my area of central Florida, they have told me to stay away from the dealers. Most techs now a days weren't even in diapers when the '85 was in production. So I guess I will have to tackle this myself. The shifting points in my C4 are all off. It wants to run through all the gears before I hit 40MPH. I know this is not right, though this is my first Vette.
If somoeone could give me some advice on how to adjust or what ever it is I need to do to protect the tranny from any damage I would approceiate it. The engine has 80K miles and runs great. I added some SeaFoam to the tranny to see if it might just need some cleaning but it dos not seem to help.
Old Aug 31, 2013 | 10:00 PM
hooked073's Avatar
hooked073
adjust the actuator cable
Old Sep 1, 2013 | 02:07 AM
Cliff Harris's Avatar
Cliff Harris
That sounds like normal operation to me. The engineers set up the shift points to be as low as possible to increase gas mileage.
My car will shift into second just by letting it idle in first gear. Then it lugs and drops back into first.
My car will shift into 3rd at very low speed, like 12 MPH if I give it very light throttle.
I don't drive in OD unless I'm going over 50 MPH, so I don't know what speed it will shift at.
On my car TCC is programmed to lock up at 40 MPH. It doesn't matter what gear it's in.
Old Sep 1, 2013 | 04:57 AM
kenmohr's Avatar
kenmohr
Yep. 37mph to 4th or OD
Old Sep 2, 2013 | 04:03 PM
tunedport85inject's Avatar
tunedport85inject
May be your governor isn't a Vette governor.You can fine tune your shifting point by changing governor weights and springs.You can use a shift kit to make your shifting firmer and agressive.Change TV cable setting let you raise shifting point,but most trans rebuilder dissuade you from doing this.
To c4 auto transmission shifting
