engine hesitation
Old Sep 1, 2013 | 12:19 PM
jdbuster's Avatar
jdbuster
Cruising
Default engine hesitation
I have a 1990 vette that has the L98 TPI engine I've already changed apark plugs wires and checked distributor cap and rotor, Checked fuel pressure(41.8psi) qnd changed the map sensor. The engine hesitates when throttle is opened up and sometimes pops a little is there anything that may come to mind that will help solve this problem' The engine has 74,000 miles on it. Also the INFL REST light is on, Ihave already cleaned and applied dielectric grease to sensors. Its not showing any faults right now on scanner. Help JDBUSTER !st vette
Old Sep 2, 2013 | 12:52 AM
Cliff Harris's Avatar
Cliff Harris
The "pops a little" symptom is a timing problem 99.99% of the time. Your timing might be too far advanced. Check and set to 6° BTDC. Disconnecting the EST connector will set error code 42, so be aware that will happen. You can ignore it and the ECM will purge the error after 50 restarts.
When I had a hesitation it turned out to be a vacuum leak. They can be very subtle and not in an obvious place. Mine was where the PCV hose connects to the intake manifold. Another non-obvious one is an EGR valve that is not closing completely.
Old Sep 2, 2013 | 03:47 AM
jdbuster's Avatar
jdbuster
Cruising
I checked for vaccum leaks but found none also checked EGR valve using test method shown in forum. I tested the TPI it loses voltage about midway throttle opening then jumps back on with 3.0 ma. by tester. going change this frist and see if it helps. If not will still need help Thanks if you think of anything esle please lett me know
Old Sep 2, 2013 | 08:10 AM
WW7's Avatar
WW7
Im guessing the TPS is whats causing the problem..Mine did the same thing until I got a new one...Try to get a AC Delco if you can , they sometimes sell them on ebay...WW
Old Sep 2, 2013 | 10:37 AM
raiderz's Avatar
raiderz
ACDelco TPS at Rock Auto
http://www.rockauto.com/catalog/more...373&cc=1041275
Old Sep 2, 2013 | 02:51 PM
jdbuster's Avatar
jdbuster
Cruising
I changed the TPS and it made a world of differance, engine runs great. Now to tackle the INFL REST light. I cleaned the sensors on Frame and added a ground strape to top side of sensors and installed new bolts on frame so I have a good ground. I read something about a K pin is that located on the analizer plug for car and what position is it. I think it said to ground to seat frame for three seconds with key switch in on position.
To engine hesitation
