Electrical Problems 1990 Coupe
Old Jul 1, 2002 | 05:35 PM
jtalvy's Avatar
jtalvy
Default Electrical Problems 1990 Coupe
Can anyone suggest what to do to check into my problem.
I had a problem that started about 6 months ago and showed up by the speaker in the back right putting out a loud static sound and I would have to shut off the radio.
Now this is still happeneing but now the horn stopped working and the airbag light remains on in the dash.
Any suggestions would be greatly appreciated.
Old Jul 1, 2002 | 06:09 PM
Flame Red's Avatar
Flame Red
Default Re: Electrical Problems 1990 Coupe (jtalvy)
OK, I'll take a stab. It sounds like you have three seperate problems.
For the speaker static, your capacitors in the fine Blose amp have probably gone. You can try to replace them yourself, https://www.corvetteforum.com/techti...D=58&TopicID=2 or you can get them bebuilt for about $100 each, or you can rip out the whole sucky system and replace with something excellent.
For the air light, try: https://www.corvetteforum.com/techti...D=46&TopicID=2 as this usually fixes the problem.
As for your horn, it could be the fuse, the horn itself or the switch. You will have to use some electrical diagnosic techniques to figure it out. A simple VOM meter from Radio Shack would be sufficent to test to see if the horn out.
Good luck
Old Jul 1, 2002 | 06:15 PM
jtalvy's Avatar
jtalvy
Default Re: Electrical Problems 1990 Coupe (Flame Red)
Thank you very much for the info. I know I checked all the fuses and none are blown.
I just couldn't help to think that all of these problems were related because they all appeared at the same time.
Old Jul 2, 2002 | 09:47 AM
92TripleBlack's Avatar
92TripleBlack
Did you check the second fuse box behind the carpeted panel under the passenger side dash? It is only accessable by unscrewing the panel.
Old Jul 2, 2002 | 09:37 PM
jtalvy's Avatar
jtalvy
Default Re: Electrical Problems 1990 Coupe (92TripleBlack)
Well... haven't checked the second fuse box yet but have now removed the right rear speaker and upon inspecting the AMP I found a transistor absolutely fried.....
Will have to check the other three....
To Electrical Problems 1990 Coupe
