Tuning Up Recently Inherited 1990 Corvette
Old Sep 4, 2013 | 12:47 AM
Epitome's Avatar
Epitome
Default Tuning Up Recently Inherited 1990 Corvette
I had posted a thread in general discussions about this 1990 Corvette with 70k original miles I just inherited. I have decided to keep it and play with it a bit. I just want to tune it up from scratch. Fluid changes, plugs, wires, air cleaner, etc. I haven't played with an HEI distributor since my first performance car when I was 17, a 1975 Camaro. I plan on changing the coil, module cap rotor wires etc. and my inclination is to simply use AC Delco stuff. I do remember however, switching to an Accel super coil on the Camaro and noticing a difference, also playing with the weight of the springs in the distributor. Is there a proven set up that is better than AC Delco? Or should I just put stock stuff back in? Also, I am looking at this cat back exhaust....seems economical and nice...any thoughts? Thanks http://www.jegs.com/i/Borla/157/140082/10002/-1
Also, any advice would be appreciated. Trying to keep it running well and fairly dependable.
Old Sep 4, 2013 | 07:45 AM
AirForceOne!'s Avatar
AirForceOne!
Good idea to start from scratch on your tune up, that way you know when everything was done!
The new exhaust is a good idea, because your current mufflers are really a single outlet, one is a dummy!
Do a search on the forum, there are many comments on the different mufflers and drone.
I don't think you will get a big enough change with the different coil to mess with it. I would keep it stock, but just my opinion!
Old Sep 4, 2013 | 08:25 AM
tbirdsps's Avatar
tbirdsps
Old Sep 4, 2013 | 08:53 AM
Epitome's Avatar
Epitome
That was kind of my feeling...I have a 900hp Buick Grand National....and that is not near the fastest car in the world, so messing with possible quality concerns for less than 1hp on a 245hp car doesn't make sense. I just want to enjoy it for what it is.
Old Sep 4, 2013 | 10:14 AM
Churchkey's Avatar
Churchkey
No springs in the distributor spark advance is electronic.
Find the tan wire with black stripe & black connector @ the top of the brake booster. Unplug it then set the timing. 6 degrees is the factory setting some here run a few degrees more. Reconnect the black tan wire.
Stock exhaust chokes the engine your on the right track changing the mufflers suggest eliminating the pre cats.
Old Sep 4, 2013 | 10:21 AM
Epitome's Avatar
Epitome
Yeah thanks for the reply....the last I worked with the HEI was on that 1975 Camaro, as I said. I am sure it changed at least a little from 75 to 90 lol....I am so used to working on distributorless now. I will change the basic parts that I know could go, just to make it at least seem more reliable in my mind lol. I still don't see any opinions about that Borla S Type exhaust except for a few on c5s that seem to like them.
Old Sep 4, 2013 | 10:35 AM
Epitome's Avatar
Epitome
Also.....any preference on the spark plugs? I always use stock in the GN...would there be any point to using platinums? I think the stock ones ar AC Delco R45TS, I will look it up.
To Tuning Up Recently Inherited 1990 Corvette
