Fuel pressure testing under load?
I am guessing for your car, but idle pressure somewhere near 43 PSI.
the idea behind that is when you give it gas, the manifold vacuum goes away, and the regulator will then kick in better fuel atomization and possibly more fuel at 5 PSI higher. when you let off the gas, and the vacuum returns in the manifold, the fuel pressure goes back down to 42-45 PSI.
I usually leave the vacuum off my regulator. it starts better like that anyway.
I had PCM do a retune after installing heated O2 sensors. Was running on the rich side at idle with that gassy smell you get without catalytic converters. After retune I don't have as bad a smell and she idles a little better. They must have pulled some fuel? It doesn't seem to run as good under full throttle though.
I checked the pressure AT idle after the engine was built but never under a load. I hear a lot of 383 guys talk about upgrading the pump to a 255 lph to help maintain GPM. It doesn't fall flat or anything at W.O.T. but am curious if there is a little more to be had.
I am getting 42-ish psi under full throttle and drops to 35-ish for a couple seconds when I let off the throttle. this is with the vac. line on.
I guess the only way to really know would be to buy a pump and adj. regulator and rent a DYNO $$$. At the end of the day I don't know if it is worth the cost. I think I read the stock pump is around 160-180 LPH. What crank HP will the stock pump support? I have never Dynoed my motor but the specs are in-line with other claimed 450-hp 383 c.i. motors.
