glowing exhaust piece?
Old Sep 4, 2013 | 07:54 PM
rgouette's Avatar
rgouette
Default glowing exhaust piece?
just noticed the unit(cat?) was glowing red hot...
it's just before where the tailpipe splits off into two..
the mesh covered ..thing
Rich
Old Sep 4, 2013 | 08:08 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Something is not working correctly, you are running very rich and your cats will be toast soon if not already. Ecm is getting a lean signal and is beefing it up.
Old Sep 4, 2013 | 08:10 PM
rgouette's Avatar
rgouette
hmmm
Old Sep 4, 2013 | 08:44 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
Check your plugs and wires.
Old Sep 4, 2013 | 09:01 PM
leesvet's Avatar
leesvet
pull the codes.
if its rich enough to do that there will be some sort of code stored..
Could be as simple as a tired o2 sensor or worn injectors that are spraying wet fuel. Do you have stock injectors or have they been replaced yet?
Old Sep 4, 2013 | 10:00 PM
hooked073's Avatar
hooked073
I agree with leesvet about pulling codes although if something is active the ses light should be on. I also do not think just because it is acting up it will nessary throw a code. It does sound like you are running rich. there are a few things that could cause this. Injectors on top of the list all the way down to temp sensor out of wack. A good scan would be where I would start to make sure things are doing what they should
Old Sep 8, 2013 | 09:25 PM
rgouette's Avatar
rgouette
ok, it's all making sense, as
1) I had a water in gas situation that's probably not totally been worked/flushed out of the system yet
2) today, I took it for another short test run, and it stalled on the way back: I limped it into the yard, and restarted: found injectors doing more dribbling vs spraying...so lean condition fer sure..
I wonder if the FP sock got waterlogged & isn't doing it's job now.
I probably also need a reading of fuel pressure...
O2 sensor is new, btw
Old Sep 8, 2013 | 10:30 PM
ch@0s's Avatar
ch@0s
you are running rich. It could be a vacuum leak. Have you had runners/intake off lately?
Old Sep 9, 2013 | 03:00 AM
Cliff Harris's Avatar
Cliff Harris
A bad CTS (Coolant Temperature Sensor) or bad connector or bad wiring will cause the ECM to think the engine is cold and richen the mixture. The CTS that the ECM uses has a two wire connector. I don't know where it's located on an '84. Probably on the front of the intake manifold near the thermostat.
Old Sep 9, 2013 | 03:31 AM
desertmike1's Avatar
desertmike1
A Obstructed Cat could also cause excessive heat build up..
http://www.freeasestudyguides.com/en...cuum-test.html
Old Sep 9, 2013 | 06:23 AM
rgouette's Avatar
rgouette
well, I've had the intake off tons while doing injector work, but always replace the one vacuum line.
The car sat in someones garage for a long time, I wonder if there's "stuff" up in the exhaust?
could be any of these I suppose..
I like that vacuum page, I'll see about doing a test using the gauge.
Thanks fellas,
R
To glowing exhaust piece?
