Looking for a Scanner for 89
Old Sep 4, 2013 | 08:59 PM
89ragtop's Avatar
89ragtop
Default Looking for a Scanner for 89
Looking for the best deal on a Scan Tool for an 89 Corvette. I live in Ottawa Ontario Canada.
Old Sep 4, 2013 | 09:29 PM
vetteoz's Avatar
vetteoz
What do you want to do?
Pull the codes or monitor engine operation ?
A $60 USB cable lets you monitor and record for playback real time on any laptop
Old Sep 6, 2013 | 06:54 AM
89ragtop's Avatar
89ragtop
I can read the codes. I want to be able to monitor engine operation. Tell me more about the USB cable and I presume there is proprietary software suitable for a 89 TPI engine?
Old Sep 6, 2013 | 08:08 AM
vetteoz's Avatar
vetteoz
http://www.aldlcable.com/
The links at the bottom of that page detail various dataloging programs
Datamaster is most user friendly ,especially for playback of logs recorded ,is free to download and gives 20
free datalogs before you have to buy.
Download and install this
http://www.ttspowersystems.com/softw...M-32-setup.exe
TunerPro RT is the program of choice for TPI tuners; does dataloging and allows reprogramming of the tune
in the ECM ( with other hardware like a chip burner.)
Need to download the TP program itself
http://www.tunerpro.net/download/Set..._v500_8200.exe
and the two files relevant to your MAF engine from the $6E list ( 89 F/Y ) here
http://www.tunerpro.net/downloadBinDefs.htm
Will probably need some help from here on setting up the correct Comms ports on your laptop in order for them to communicate correctly with the ECM
To Looking for a Scanner for 89
