Signal Light Steering Column Part
Cancelling cam (26047013), turn-signal switch (1995974), left spring (1964785), right spring (1964784). Your contact should be able to either hand you these parts or show you images.
The wiper/pivot assembly (26015119) is NLA but available new either in eBay or several other after-market suppliers, $80 maybe!
The only metal lever connector piece (26020396) is NLA but it's an unlikely failed part. Could it be? Yes!
In this image everything is shown except the cancelling cam. The lever is attached to the turn-signal switch with the two cross screws on the left, the springs I mentioned are visible one at top and the bottom is hidden I believe because the lever is in the right turn position. The cancelling cam drops right in the center over the coil spring you see followed by the lock plate:
[IMG]
[/IMG][IMG]
[/IMG]
