Best o2 sensor?
Old Sep 8, 2013 | 07:50 PM
95wht6spd's Avatar
95wht6spd
Default Best o2 sensor?
One bank is running rich, going to try to fix by changing o2.
What is best 3 wire for 95?
Any ones that last longer or ones to avoid?
Old Sep 8, 2013 | 08:06 PM
JMelton's Avatar
JMelton
In my opinion, you can't go wrong with Bosch.
Old Sep 8, 2013 | 08:42 PM
jmalez's Avatar
jmalez
I had the same problem on mine but it turned out to be a bad spark plug cable causing a lean condition causing the pcm to richen up the mixture, as for brands I would stick to an ac/delco,
Old Sep 8, 2013 | 10:02 PM
SeeFourSix's Avatar
SeeFourSix
Bosch & Delphi
Old Sep 8, 2013 | 10:26 PM
95wht6spd's Avatar
95wht6spd
I have heavy MSD wires, no burned spots so don't think it is wires, but will keep in mind.
To Best o2 sensor?
