Officially stopped using Mobil One Today
Old Jul 2, 2002 | 07:21 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Re: Officially stopped using Mobil One Today (PeteL)
Sorry, I've been at the cape all day.
It's dino oil,
Three reasons actually,
First with a 130k 55k of which are very hard miles I've been pushing some oil by the rings. So I'm going with the thicker oil to reduce this problem
Second, I've heard that the additives that Valvoline uses in there VR series oil is much better espicially for high HP engines. I'm not in that range yet but what the hell
Thrid, It's still very expensive for dino oil but it is 1/2 the price of Mobil One.
I still will use Mobil One when running road courses because I believe that Mobil One is way better when heat comes into play.
Old Jul 2, 2002 | 07:27 PM
L98Terror's Avatar
L98Terror
Default Re: Officially stopped using Mobil One Today (87TRex)
Allright I'll join in too. What the F#*k are you thinking man?!? I use 20-50 in the summer as well, but Valvoline can't hold a candle to Mobil 1. That's a proven fact. Let us know what you're thinking. :U
How was it proven to be better, I'd like to see the data. When I pulled the heads on my Vette at about 110k there was so little wear you could still see the cross hashes in the cylinder walls. I took my heads to the machine shop and they could believe that they had over 100k because the were in perfect shape. I can tell you the first 75k the Vette never saw Syn. oil it was switched to Mobil One at about 75k.
Old Jul 2, 2002 | 07:29 PM
L98Terror's Avatar
L98Terror
Default Re: Officially stopped using Mobil One Today (shera)
Ken,
It looks like that new oil is slowing you down!!! :D
Actually the Vette is running as strong as ever
Old Jul 3, 2002 | 09:25 AM
shera's Avatar
shera
Default Re: Officially stopped using Mobil One Today (L98Terror)
I was refferring to your quarter mile times in your post!!! Which we know Val can pull on 6 cylinders.
Old Jul 3, 2002 | 09:52 AM
The Rex's Avatar
The Rex
Haven't you seen that commercial where they cook two pans of oil on the stove. There's your data! :eek: What more proof do you need? As Bo Roberts says "They couldn't print it, if it weren't true." :jester
Old Jul 3, 2002 | 10:07 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Dino oil WILL NOT handle the high temperatures generated by our Vette motors. Changing to a Dino because of oil use is masking a symptom. Motors are designed to use oil, particularly under hard running. Higher viscosity oil will not lub all the small little places needed. To make a long story short, don't believe what you see on TV...look at the facts. Sure Synth is more expensive...but is does a significantly better job.
Old Jul 3, 2002 | 01:33 PM
ColinOpseth's Avatar
ColinOpseth
Default Re: Officially stopped using Mobil One Today (PTz-92-LT1)
i thought that people switched to synthetic BECAUSE it has a higher flash point, making it less apt to burn off than a dino oil?
something doesn't make sense here, i think you're going the wrong way :) also look at the extra wear during starting, yada-yada..
Old Jul 3, 2002 | 05:54 PM
Deadcarny's Avatar
Deadcarny
oh, i thought it was the synth. what is the valvoline synth oil called?
Old Jul 3, 2002 | 06:15 PM
L98Terror's Avatar
L98Terror
Actually my engine came with Dino oil, it wasn't till the LT1 that GM starated using syn
Old Jul 3, 2002 | 06:17 PM
L98Terror's Avatar
L98Terror
If you go over to the Kill or Northeast section you will see why I don't post my times any more.
Last night we meet a group of F bodies and had a show down so far Val is 1-0 with many more talking poopie :D
