1986 L98 Flange Torque Specs
Old Sep 12, 2013 | 02:50 PM
Ghast's Avatar
Ghast
Default 1986 L98 Flange Torque Specs
Trying to tighten my exhaust back on, but even at 30ft-lbs, its still leaking. Should I go tighter?
Old Sep 12, 2013 | 04:24 PM
383vett's Avatar
383vett
Did you use new gaskets? Is the flange warped?
Old Sep 12, 2013 | 05:40 PM
Ghast's Avatar
Ghast
I could be wrong, but I thought the exhaust flange was a metal on metal ball and cup connnection, no gasket. Flange doesnt look warped.
Old Sep 12, 2013 | 06:39 PM
383vett's Avatar
383vett
Oh, I thought you were talking about the header flange that bolts onto the head. Strike my last comment.
Old Sep 12, 2013 | 07:51 PM
ch@0s's Avatar
ch@0s
take some sand paper and clean both surfaces.
Old Sep 12, 2013 | 08:12 PM
383vett's Avatar
383vett
Use the orange hi-temp rtv at the joint. That should seal it.
To 1986 L98 Flange Torque Specs
