86 egr temp switch
Old Sep 13, 2013 | 05:53 PM
86 pace car's Avatar
86 pace car
Default 86 egr temp switch
Tommorrow im going to change the egr temp switch on my 86 any tricks to disconnecting the harness that under the distibutor thanks
Old Sep 13, 2013 | 06:02 PM
C4boy's Avatar
C4boy
If I remember... small hands work best! Remove the dist. cap. I think I held both parts of the connector in one hand and used a screwdriver to carefully separate them in the other hand. Not sure if I removed the oil pressure sending unit or not. It's one of those things that takes patience.
Old Sep 13, 2013 | 07:34 PM
3D87C4's Avatar
3D87C4
I disconnected, adjusted, then reconnected my '87 EGR temp switch. It pulled apart easily enough but getting it back was tricky. IIRC it was just a contortionist, one hand, operation---big hand in a small space.
Old Sep 14, 2013 | 10:56 AM
Cliff Harris's Avatar
Cliff Harris
I found it VERY difficult to get the connector apart. I used a screwdriver from the driver's side to push on it.
I put silicone grease on it to make it easier. When I had the distributor out I rerouted the wires to make it more accessible. Now it comes apart easily and I don't have any trouble getting to it.
Old Sep 14, 2013 | 01:25 PM
Corvette40's Avatar
Corvette40
I found an old plug and used the male end from the old temp switch and made a 6" extension. No problems now.
To 86 egr temp switch
