Rt Front Pad sticking or dragging.
Old Sep 14, 2013 | 10:11 AM
dlee425's Avatar
dlee425
Default Rt Front Pad sticking or dragging.
New problem came up yesterday. Driving home I noticed the rt side rim was hot and smoking. As i was driving the pedal went to the floor and was able to make it home using the e-brake. After It cooled down last night the pedal works fine again and stops good. I do know that the pads are getting a little worn.
As iam on a limited budget.. What would be a good guess to start with. New pads, brake hose or something else.
Its seem to be only the one side.
Thanks...
Old Sep 14, 2013 | 10:26 AM
don hall's Avatar
don hall
http://www.ehow.com/how_5068269_calipers-sticking.html
Old Sep 14, 2013 | 11:10 AM
Cliff Harris's Avatar
Cliff Harris
The brake pedal went to the floor because the brake fluid boiled in the caliper. That's most likely caused by water in the brake fluid. You need to bleed/flush the system with new brake fluid before doing anything else.
Old Sep 16, 2013 | 06:26 AM
dlee425's Avatar
dlee425
It was the stuck caliper. Has nasty brake fluid. Had to replace the master cly. Noticed it was leaking out the front between it and the booster. Shocked advance auto had it. Thank goodness i had a code foe 20% off if bought online. Did order the caliper rebuid kit from napa.
Going to flush the system today.
To Rt Front Pad sticking or dragging.
