What does everyone use for wiperblades?
Old Sep 14, 2013 | 04:43 PM
Lucky86's Avatar
Lucky86
Default What does everyone use for wiperblades?
Im having a problem finding blades for my 90 Zr1 because,the ones i bought are to "high" and cant fit between the hood and windshield. I need some blades that are Lower profile. Thanks for the help.
Old Sep 14, 2013 | 04:53 PM
Czarvtte's Avatar
Czarvtte
Been hearing good things about Trico 20-2 blades....gonna replace my factories with those soon.
Old Sep 14, 2013 | 06:54 PM
HlhnEast's Avatar
HlhnEast
I bought RainX Latitudes I think and was pretty disappointed. They wipe good enough, solid construction and conform well but they just wont stay locked on my wiper arm. I finally put a small zip tie on each of them and they are at least staying put for now. It never rains in Florida, what do I need wipers for anyway.............
Old Sep 14, 2013 | 08:02 PM
WVZR-1's Avatar
WVZR-1
If yours are still the OE just put inserts in them!
Old Sep 14, 2013 | 08:50 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
I put them on my 92 about a year ago. They set like they should and work fine.
Old Sep 14, 2013 | 09:58 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
That is what I did with my '96
Trico Wiper Blade Refill - Part#: 45-200
Old Sep 14, 2013 | 10:18 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Don't need wiper blades, doesn't rain here.
Old Sep 15, 2013 | 02:25 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Trico 20-1 OEM repop's, or 20-2 perforated wiper arm, but still fully functional.
Old Sep 15, 2013 | 08:58 AM
Larrye's Avatar
Larrye
Have AC-Delco professional line blades that fit well, many of the Delco blades are supplied by Trico.
Old Sep 15, 2013 | 05:55 PM
Birddogtwo's Avatar
Birddogtwo
I spent 45 minutes at a local parts store trying every blade they could think of. I ended up going to my local Chevy dealer and ordering them. 2 different part numbers for drivers side and pass. they cost $38 for the pair. pricey but I think the old ones were original eqipment. so only $2 per year. If you look at it that way it was a bargain
By the way 96 CE
Old Sep 15, 2013 | 06:31 PM
WVZR-1's Avatar
WVZR-1
Ideally I believe the '95 - '96 are the better but for an initial upgrade for '94 or earlier it requires arms from the '95 - '96 also. The arms I believe are likely only available used now.
Old Sep 15, 2013 | 07:16 PM
cumbercr's Avatar
cumbercr
Skip the wipers. Drive faster.
Old Sep 18, 2013 | 12:11 PM
JrRifleCoach
The Trico set was $15/pair and hadn't been sitting in a warehouse for ten years
Old Sep 22, 2013 | 11:47 PM
Bubba91's Avatar
Bubba91
I upgrade my 91 with the 96 wiper arms and blades. Then, I just use inserts. Guaranteed to fit.
Old Sep 23, 2013 | 12:49 AM
Johnfur's Avatar
Johnfur
i went through this and wasted a lot of time. The original equipment blades are a side mounting with a plastic insert that shims the shaft for a proper fit.
Went to several auto parts stores and tried several replacement blades, the mounting hole is too large for the mounting shaft. Therefore, the replacement blade wobbled.
Go to a General Motors dealer and order the proper blade, they are only $12.00.
The replacement blade has been re-designed with a replacement hole that fits the shaft properly and eliminates the plastic insert bushing.
The blades fit properly with no wobble.
To What does everyone use for wiperblades?
