Normal idle for a '93??
Old Sep 14, 2013 | 08:49 PM
jimkari's Avatar
jimkari
Default Normal idle for a '93??
Every since I've owned my '93 (about 7 years and 44K to now 93K miles), it has exhibited what I'd consider a high idle. When I take my foot off the accelerator the engine will drop to 1,000 RPM. After sitting awhile at stop light it will drop slightly to about 900 RPM. I tried one tip on the Forum about resetting the IAC, (starting engine, unplug IAC, shut off engine, remove key, plug in IAC, and restarting engine). When I did this the engine dropped to 600 RPM and idled well, but as soon as I accelerated, the idle went right back to 1,000 RPM.
Is this normal and if not, any thoughts on a possible cause?
Thanks,
Jim
Old Sep 15, 2013 | 12:07 AM
don hall's Avatar
don hall
Thanks, Jim
No, it is not normal, and a new Idle Air Control Valve may solve your problem (?)
Old Sep 15, 2013 | 05:06 AM
toptechx6's Avatar
toptechx6
If you are using the tach on the instrument panel to determine idle speed I suggest checking it with a scan tool. By the vehicle tach my 93 would seem to idle at nearly 900, actual is below 700.
Old Sep 15, 2013 | 09:54 AM
jimkari's Avatar
jimkari
Thanks guys, I appreciate the tips. I was thinking about the tach being off. I may also look at replacing the IAC.
Jim
Old Sep 15, 2013 | 12:26 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
If you do pull the IAC, take off the throttle throttle body, and give it a good cleaning. That includes the air orifices to the IAC.
FWIW, I had the same high idle in my 92, and that was only resolved after the ECM was repaired for another issue.
Old Sep 15, 2013 | 12:56 PM
jimkari's Avatar
jimkari
Thanks for the tip. I cleaned the IAC, and throttle body, then reset the IAC. I drove the car for a few minutes and the idle was right around 700 RPM. After letting the car sit for about 45 minutes, the idle is back to 1,000 RPM. I'm thinking it might be the IAC itself. I can pick up a Delphi unit for about $62. Might be worth a try unless any others have some suggestions.
Thanks again,
Jim
To Normal idle for a '93??
