Light knocking sound about 5 mins after warming up. I can only hear it at idle. Remove belt, quiet, no knock. New belt, tensioner, air pump, alt. If I spin water pump, PS pump, A/C by hand, they seem smooth with no runout. The only other way I can stop the knock at idle is by slipping the clutch with e-brake on and pulling the engine down to ~6-700 rpm under load. Strange. Any ideas?
I checked all accessory mounts for tightness as well as pulleys and crank bolt.
You can tell if the outer ring of the harmonic balancer has moved by looking at the hole in the rear of the timing tab. The rear edge of the harmonic balancer should be visible through the hole. This isn't a C4, but it shows the relationship:
A mechanic's stethoscope will let you listen to the various accessories while the engine is running. You can find them for very little money with a little searching.
Mine is much further forward than the one in that pic but the pulley is still in line with the other accessories and the balancer won't move fore or aft with a crowbar.
There is a bolt holding the harmonic balancer to the crank, as you mentioned in your first post. The harmonic balancer has an interference fit with the crank so it's on there pretty tight. You need a special puller to get it off.
The belt pulley is bolted to the center hub of the harmonic balancer. The outer ring can move without affecting the pulley alignment.
Tried a few different things today. Made a mark between the two halves of the harmonic balancer. No movement, yet. Probably the most telling thing is this, If I put my breaker bar on the tensioner and push loose, sounds goes away 99%, if I pull and increase tension on the belt, sound goes away 100%. I think it must be the harmonic balancer but I want to be sure before I pull it. What do you guys think?
You can check the harmonic balancer to see if the outer ring has turned by lining up a straight edge with the edge of the spoke nearest the timing mark, like so:
Checked static timing today and the marks line up, so I don't think the outer ring has migrated. I can't completely rule out the harmonic balancer yet but I'm thinking a cracked accessory mount or something loose I can't see is hitting when warm?
get a sepothscope 20 bucks at auto store. run car and place scope to every thing that could make a noise. The air pumps on these things are know for knocking then coming apart. they will turn by had ok but when you rev them up and put a load on them different story
get a section of hose, water hose, anything. Run the engine at idle and place the end of the hose on the various things and stick the other end to your ear...LISTEN. Listen and learn what you are hearing.
Suddenly small things like injector clicks are thunderous....and big things like bearings failing sound like cement blocks grinding against each other.
The idler WILL cause a squeal or chatter. The bushing inside is a plastic/poly material that wears out and lets the idler slip for/aft as it starts bouncing at idle. There is no fix, replacement only. Shop around...those can go for well over $100 while some
sell for <$75
The hose/ stethoscope works...you can use a screwdriver BUT, that can be very dangerous. You have to look away to get your ear on it and IF YOU SLIP....you can get tangled in the belt on a running engine and get a screwdriver stuffed thru your head.
No solid objects (including your face) around or near moving parts.
I had a similar noise on my 88 Vette, it sounded like it had a cam shaft gear drive installed, it had a really distinctive whine that I swear was coming from inside the engine. Even using a piece of hose as a stethoscope and checking all the accessory drives didn't narrow it down.
With the serpentine belt removed the noise went away so I knew it had to be either the ps pump, alternator, smog pump etc, they all seemed fine when spun by hand.
I just happened to have a spare new alternator so I swapped it in, that fixed it, noise was gone.
It weird sometimes how noise can travel/resonate and lead you in another direction.
Ken D
It weird sometimes how noise can travel/resonate and lead you in another dire action.
Ken D
Exactly. It's not easy to find the source of the noise. I've replaced the alt, smog pump and tensioner. The sound goes away when I take off the belt. Will be using a stethoscope today to try and narrow it down.
It's either the water pump, PS pump or A/C. Everything else has been ruled out. Could it be a cracked accessory mount that only knocks when it gets warm? I've used a prybar where I can fit it but can't find anything.
I've discovered that these tensioners can be responsible for a whole bunch of weird symptoms and sounds...
they get weak, bearing gets loose and they cause chatter, thumping rattling noises that just can't be explained.
if you take note of the nylon bushing inside the tensioner and how much you can see...the more that slips out and the more that can be seen is an indicator of how bad the tensioner is.
these belt tensioners ARE wear parts just like brakes and tires.
