manifold air temp sensor on 85?
Old Sep 18, 2013 | 03:32 PM
85corvettec4's Avatar
85corvettec4
Default manifold air temp sensor on 85?
is there a manifold air temp sensor on an 85 that screews into the bottom of the plenum? because i have some broken sensor in there and is this it? http://www.autozone.com/autozone/par...44824_0_0_4439
Old Sep 18, 2013 | 04:11 PM
cumbercr's Avatar
cumbercr
Yes and it looks like the one in the link.
Old Sep 18, 2013 | 06:03 PM
85corvettec4
awesome! thanks man.
Old Sep 18, 2013 | 06:23 PM
MrWillys's Avatar
MrWillys
Actually the oem one is the same as the coolant sensor and the tip is solid brass. Your link is the updated version, so don't get worried if it's slightly different.
Old Sep 18, 2013 | 07:57 PM
85corvettec4
great! i splurged a little bit to get it all up together couldve almost gotten a ram >.<
Old Sep 18, 2013 | 10:25 PM
85corvettec4
any idea what these are?
Old Sep 18, 2013 | 11:08 PM
John A. Marker's Avatar
John A. Marker
Your car should have recorded and error code 25 for the bad.disconnected sensor on the underside of the plenum. Technically this is called the IAT Intake Air Temperature sensor
I think you might have idle problems with the looks of the IAC. Looks like it took on a little water. I know that Washingtonians don't tan, they rust. But I didn't know that this also applied to the IAC!!
Old Sep 18, 2013 | 11:54 PM
85corvettec4
thats my cold start switch and my idle air control valve ;( $200 worth of sensors
Old Sep 19, 2013 | 03:42 AM
Cliff Harris's Avatar
Cliff Harris
Watch out for the connector type. The connectors changed in 1987 and the later parts won't plug in.
The MAT (Manifold Air Temperature) sensor harness is about 12" long. I would take it to the auto parts store to make sure it plugs into the new sensor.
Old Sep 19, 2013 | 07:44 AM
86 iron's Avatar
86 iron
Was the MAT sensor on the early cars only to turn the EGR on?
Old Sep 19, 2013 | 09:28 AM
John A. Marker
Next time you need parts, check out RockAuto online. There will be a small shipping charge, but most of the time you can save considerable money.
I was up en Everett last week on Colby. The weather was great.
Old Sep 19, 2013 | 09:45 AM
cumbercr's Avatar
cumbercr
No. The EGR is enabled by a temperature switch at the base of the EGR valve.
Old Sep 19, 2013 | 09:47 AM
MrWillys's Avatar
MrWillys
It is the only table in the programming that I've seen. IE: The AANM BCC shows the EGR enable temp as -17.50 C.
cumbercr's Avatar
cumbercr
And most of the time you will have the option of purchasing original AC Delco parts.
Old Sep 19, 2013 | 10:31 AM
85corvettec4
rock auto has em both for the price of 1 at oreillys, awesome stuff
Old Sep 19, 2013 | 11:25 AM
cumbercr's Avatar
cumbercr
The EGR duty cycle is controlled by the ECM using inputs from the CTS, TPS and MAF.
Old Sep 19, 2013 | 11:35 AM
MrWillys's Avatar
MrWillys
I believe the question was specific to what the MAT does? The only caveat in the programming is in reference to the EGR enable temp that I'm aware of? Fuel not being dependent on it as suggested by others.
To manifold air temp sensor on 85?
Old Sep 19, 2013 | 12:17 PM
cumbercr's Avatar
cumbercr
According to the FSM, the only purpose the MAT serves is to delay opening of the EGR until manifold temps reach 5 Deg C.
The EGR temperature switch is a diagnostic switch. It senses heat from exhaust gases downstream of the EGR. If the switch does not heat up and close within 4 minutes of the EGR opening, a code is set.
Old Sep 19, 2013 | 12:36 PM
MrWillys's Avatar
MrWillys
Interesting? I find it amazing the difference between the FSM, and what is actually programmed. I opened a 86 AANM this morning and it showed -17.50 C. The FSM also says the fans come on at 228, but they're programmed at 107.75 C which converts to 225.95 F. I know I'm being picky, but you'd think they'd be more accurate.
Old Sep 19, 2013 | 01:16 PM
cumbercr's Avatar
cumbercr
There certainly are discrepancies between the manual and real life. The stock BIN for the 85 uses -17.5 C as the minimum MAT temperature. Yet the book clearly states 5 C as the minimum. That's a significant difference.
My manual states that the cooling fan should run if coolant temperature is greater than 106 C. But the constants table is set for 107.75 C.
