TIRE PSI??????
Old Jul 2, 2002 | 07:44 PM
Mile High
Mile High "91"
Default TIRE PSI??????
I have a "91"auto coupe with the OE gatorbacks the fronts have about 70 % and the backs have about 50 % tread life left. What tire pressure should I run??
Old Jul 2, 2002 | 09:47 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: TIRE PSI?????? (Mile High "91")
I keep mine at 35 psi except at the track, then 45 front and 22 rear.
Old Jul 2, 2002 | 10:50 PM
Vette9d1's Avatar
Vette9d1
Default Re: TIRE PSI?????? (Mr Mojo)
I keep mine at about 33psi all around(measured when not hot of course). Seems to work great on my automatic '91.
Old Jul 2, 2002 | 11:07 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: TIRE PSI?????? (Vette9d1)
35 is the GM spec.
Old Jul 2, 2002 | 11:10 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I run mine at 35psi all around for driving and autocross.
I'm going to experiment with different pressures at autocross when I stop improving my times :yesnod:
No drag racing here, but I'd pay attention to Mr Mojo for his suggestions.
HTH
Old Jul 3, 2002 | 12:56 AM
FlyboyZR1's Avatar
FlyboyZR1
35 front, 33 rear. Is it just me or do tires not last more than 20k on these cars?
[Modified by FlyboyZR1, 10:57 PM 7/2/2002]
Old Jul 3, 2002 | 01:00 AM
VetteNoob's Avatar
VetteNoob
Default Re: TIRE PSI?????? (FlyboyZR1)
I think you may have a genetic defect commonly associated with Corvette owners. I believe the term is "Rightfoottooheavyidus". The only known cure to date is a Toyota Corolla. :D
Oh...and 32lb all around for me. no racing, yet.
[Modified by VetteNoob, 11:02 PM 7/2/2002]
Old Jul 3, 2002 | 02:56 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
35psi here :yesnod:
[Modified by 9vette3, 1:57 AM 7/3/2002]
Old Jul 3, 2002 | 04:46 AM
TIMSPEED's Avatar
TIMSPEED
Default Re: TIRE PSI?????? (9vette3)
35psi all around running 275/40 17's on the ZR1 17"x9½" 5 stars. I think I'm gonna try going down to 25psi in the rear for drag racing...see if that maybe helps. BTW my tires are Bridgestone Potenza RE730's.
Old Jul 3, 2002 | 08:58 AM
Mr Mojo's Avatar
Mr Mojo
My rears only barely last that long. The fronts on the other hand have 50,000+ so far.
Old Jul 3, 2002 | 10:13 AM
rockken_vette's Avatar
rockken_vette
I run 36 all the way around. I have Bridgestone RE730s on the front and Goodyear Eagle F1 Steels on the back. The F1s used to be all around, but due to punctures, etc, I opted for a lower cost tire this time. Might need to replace the backs in the fall. Will go again with the RE730s. They perform really well, even though I don't like the sidewall looks as much, and they were FAR less expensive.
Are all your tires wearing evenly? What about the middle of the tire vs. the edges of the tire? That might tell you something about the pressure you are running. If there is more meat in the center, jack the pressure up a bit.
Ken
Old Jul 3, 2002 | 12:44 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: TIRE PSI?????? (rockken_vette)
Yeah it's weird. I'm the second owner, but haven't been too hard on this set of tires at all. They were almost new when I got them, and I"ve put 10k on them. The wear is pretty even, but looks like maybe the edges have a bit more meat than the center. My pressues are usually around 35psi on all 4's. Maybe I need a 4-wheel alignment?
Old Jul 3, 2002 | 01:22 PM
IcemanZ06's Avatar
IcemanZ06
More wear in the center is usually an indication of either overinflation or bad shocks. My shocks were bad on my 87 and wore the centers of my wheels really badly.
Old Jul 3, 2002 | 01:43 PM
guywade's Avatar
guywade
tire pressure should 30lbs all around for just cruising around, my 2 cents
Old Jul 3, 2002 | 01:47 PM
bac22's Avatar
bac22
Default Re: TIRE PSI?????? (guywade)
Unless you are racing or autox, you should use what GM publishes on the door panel. For a 96 that is 35 PSI.
Old Jul 3, 2002 | 01:49 PM
92TripleBlack
Default Re: TIRE PSI?????? (bac22)
Verts used 30 lbs instead of 35 to smooth the ride out from the x brace. I keep mine at 33-35 depending on the time of year.
Old Jul 9, 2002 | 03:49 PM
dscottr's Avatar
dscottr
Default Re: TIRE PSI?????? (92TripleBlack)
I keep mine at 32 all the way around. When at the track I go down to 24 in the back. Noticable difference in 60 foot time with lower tire pressure in rear wheels.
To TIRE PSI??????
