rear wheel camber
Old Jul 2, 2002 | 09:55 PM
xzvs's Avatar
xzvs
Default rear wheel camber
My right rear wheel is tilted in at the top. Looks like the bottom camber adj is sucked all the way in too. Ordered 4 new neoprene bushings from Ecklers, and have the go ahead from the boss for use of our 4 wheel alignment machine the sat after they get here. Hope I am on the right track here.
Old Jul 2, 2002 | 10:31 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: rear wheel camber (xzvs)
Sounds to me like you ARE on the right track. It's more than likely a bad, (or missing) bushing, or just an ajustment of the camber bolt, easy fix..... :cheers:
Old Jul 2, 2002 | 11:48 PM
xzvs's Avatar
xzvs
Default Re: rear wheel camber (edsalinas)
Ok -neat --just was wondering if i might be forgetting something. I will be doing the alignment myself, but thats no biggie as I have been doing alignments for the last 17 years on and off. Can anyone recommend a good streetable setup, other than factory, that I can use? I can set my own values for the spec's. Even with the rear camber prob and the steering wheel a bit cocked, it handles great and rolls straight on the highway.
To rear wheel camber
