85 c4 with 206,000 miles still running strong :)
my voltage gauge is turning on and showing that the charging system is running out of spec (way low, 10-11) unless i rev the motor. i am guessing i need an alternator.
now heres the part i need advice on, i was told i could use a heavy duty optional one (120 amp) for 9 dollars more. sounds good to me but the guy at the parts store said it may not work.
so what do the rest of you think? The car has power everthing except passenger seat.
Hey welcome to CF. Did the parts guy give you any particular reason as to why it wont work? Also, you can take the alt off and have a local parts store test it to make sure it is dead before coughing up the cash for a new one. If you do buy a new one, make sure the battery is charged up before you let that new alt see it. If you have a weak battery, you will burn out your new alt faster too. AutoZone can usually charge your battery and test your alt for free and fast. Good luck.
Yup, 120amp was stock.
I replaced the alternator about 3 years ago with an AutoZone new (not refurb) model, and haven't had an issue yet. I have pulleys on the car so it spins slower than normal. at Idle I get 11.5v charging, under load I get normal 14-14.3volts.. I was thinking of getting a higher amperage unit, maybe a 160, so it offsets the slower turning of the pulley. But everything is good as it is.. Besides Im selling the car. ;-)
thanks for the information.
looks like the 120a is the right one
i would have got back sooner but i had to go round and round with oreilly's
man that store sucks (had to buy 2 of them becuase they claimed it wasnt the one they sold me, even tho i had the reciept and the original box, then the new one had a helicore in it that was the wrong size, luckly there was enough thread left to make it work once i got the helicore out)
the good news is the car is running better than ever
the second gear scratch has improved (not something i would have expected)
