Shock replacement?
Old Sep 22, 2013 | 06:49 PM
smooth1990's Avatar
smooth1990
Default Shock replacement?
I have the Fx3 shocks on my 1992 and my rear shocks are shot. I want to replace them ASAP because we have limited time left before the car goes into winter storage. My problem is, I cant find a good set to get me through the fall. I am planning on replacing the fx3 with coil overs this winter and I would like to know if I can just buy a set of kybs or something and use them through the rest of the year? Is there any issues with mounting? I am not sure if the billsteens are mounted the same as a standard shock? I am sure some of you have done this and I would like to know before I go out and rip my shocks out.
Old Sep 22, 2013 | 07:26 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
the diameter of the cylinder is different between the fx3 and standard shock, the fx3 being larger. bushings are different and I believe the top mount bracket has a different diameter hole for each. a single position should would mount up if you got the correct top shock mount.
Old Sep 22, 2013 | 09:52 PM
pkincy's Avatar
pkincy
If you are going to coil overs you might just live with what you got until you do the coilovers as that sounds like it will only be a month or two of driving.
Old Sep 22, 2013 | 11:37 PM
smooth1990's Avatar
smooth1990
Thanks sleezy.
And I might. My back shocks are totally shot tho. I hate to do a lot of driving with them like that.
Old Sep 23, 2013 | 01:15 AM
Deakins's Avatar
Deakins
Are you sure the factory mounting locations for the shocks are strong enough to support the added abuse of a coil over set up?
Old Sep 23, 2013 | 01:20 AM
smooth1990's Avatar
smooth1990
As far as I know, yes. There are a few guys on here that have done it and there are a couple companies that offer coilover setups for C4 corvettes.
Old Sep 23, 2013 | 07:35 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
The KYB's are a direct fit in place of the FX3's. The only issue I encountered was that the rubber bushing in the inside if the frame rail was so swollen that I had to drill rubber material out of it before I could pull the shock out.
Old Sep 24, 2013 | 03:57 AM
smooth1990's Avatar
smooth1990
Do you have a part number for the kybs you used? Also did you replace all 4 shocks?
Old Sep 24, 2013 | 04:58 AM
WVZR-1's Avatar
WVZR-1
There's no modifications done to the car for the FX3 at BG - if you buy correct shocks regardless of brand and use all of the appropriate hardware you'll be fine. If your FX3 is operational you might just consider a rebuild of them - if the actuators are non-functional and your doing coil-overs you'll need to think it through.
FX3 hardware is different but it's only required when the FX3 is installed.
Old Sep 24, 2013 | 05:02 AM
smooth1990's Avatar
smooth1990
Ok thats what I was wondering. The fx3 system on my car is functional but ther rears are completely shot.
Old Sep 24, 2013 | 05:11 AM
smooth1990's Avatar
smooth1990
I planned on swapping to coilovers but I may just send them in for a rebuild. I may just throw some kybs on to drive the car the remainder of the year.
Old Sep 24, 2013 | 07:08 AM
ghoastrider1's Avatar
ghoastrider1
good thing is the KYBs are made just outside of Indianapolis, Indiana, USA.
To Shock replacement?
