Stereo compatibility?
Old Sep 23, 2013 | 10:51 AM
bassackwards's Avatar
bassackwards
Default Stereo compatibility?
I have a parts 94 car that has a nice factory stereo in it with the amp in the back storage compartment.
Can this system be moved to my 92 convertible without too much hassle?
Old Sep 23, 2013 | 10:55 AM
c4cruiser's Avatar
c4cruiser
I think what you are seeing in the rear compartment is the radio receiver. On the '92, the radio receiver is located behind and above the passenger side kick panel. I think GM moved the radio receiver in '93.
Each speaker has its own amp; the unit in the dash is just a head unit.
Old Sep 23, 2013 | 11:14 AM
bassackwards
So would the system out of the 94 go into the 92 with a minimum of hassle? I don't want to rewire everything to get it to work
Old Sep 23, 2013 | 12:33 PM
WVZR-1's Avatar
WVZR-1
If both are Bose I believe the only change is the color of the buttons on the bezel face. They would both need to be Bose I believe or both would have to be the base systems. I don't know that you can mix Bose with non-Bose car or the other way around.
Old Sep 23, 2013 | 01:07 PM
aklim's Avatar
aklim
I believe it is either Bose or nothing. Supposedly there WAS an adapter made but they don't make them anymore that allowed you to use non-Bose speakers. I did toss everything out and left the wring since I was going to rewire.
Old Sep 23, 2013 | 04:08 PM
bassackwards
OK I got most of it to work already.
The CDM on the 92 is under thd dash and is a bitch to swap. The 94 is in the hatch and much easier to access.
Last concern I have deals with the speaker amps that are marked conv and coupe. I wonder how much different the sound will be.
Old Sep 23, 2013 | 08:44 PM
bassackwards
Got everything working and it sounds good enough for me. I'm using the hatch the amps and will probably leave it until it quits.
To Stereo compatibility?
