What is Power shifting?
Old Jul 3, 2002 | 12:30 AM
Ender85's Avatar
Ender85
Default What is Power shifting?
Title says it all, can someone explain it to me?
Old Jul 3, 2002 | 12:32 AM
kawboy5792's Avatar
kawboy5792
Default Re: What is Power shifting? (marthpodi)
power shifting is when you shift gears without allowing the rpm's to drop back down again. in other words you keep the throttle pinned as you row through the gears. hope this helps!
Old Jul 3, 2002 | 12:48 AM
vader86's Avatar
vader86
Default Re: What is Power shifting? (kawboy5792)
just dont take your foot off the gas
Old Jul 3, 2002 | 01:03 AM
Ender85's Avatar
Ender85
Default Re: What is Power shifting? (vader86)
that can't be good for the clutch....
Old Jul 3, 2002 | 01:08 AM
GlockLT4's Avatar
GlockLT4
it's not good for anything in your car, lol. Except your ET.
[Modified by Glock'94, 11:08 PM 7/2/2002]
Old Jul 3, 2002 | 01:09 AM
scorp508's Avatar
scorp508
Powershifting is fine as long as it is done right. :yesnod:
Old Jul 3, 2002 | 01:23 AM
J Z06's Avatar
J Z06
Default Re: (scorp508)
It's something I miss DEARLY! I loved doing it in my mid 11 second mustang gt. Unfortunately, 3 clutches 2 trannies a motor and a rear later I sold it :D
Old Jul 3, 2002 | 02:11 AM
Knight Ryder's Avatar
Knight Ryder
St. Jude Donor '05-'06-'07-'08
Yep... what everyone else said.
It is worth up to .5 in the quarter mile, but I'm not sure I can see how it is OK if done right?? :confused: Can you help me with that one Scorp?
[Modified by Knight Ryder, 1:12 AM 7/3/2002]
Old Jul 3, 2002 | 09:01 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: What is Power shifting? (Knight Ryder)
Check out my video
http://temp.corvetteforum.net/c4/mrm...ovspanuzzo.wmv
Old Jul 3, 2002 | 10:45 AM
Ender85's Avatar
Ender85
Default Re: What is Power shifting? (Mr Mojo)
so you still pulled your left leg up but left the right (accelerator) on the floor.
I've worn on my clutch quite a bit by learning to drive a stick with this car, and I'd rather not replace a clutch any time soon - so I'll leave the power shifting to you pros (until I get involved in a race I really want to win - so a couple days and I'll be power shifting like a madman)
Old Jul 3, 2002 | 12:55 PM
vader86's Avatar
vader86
most of my friends think that power shifting doesnt wear their clutches prematurely at all, because they dont shift quite as much. Still i wouldnt do it until youre good at finessing the clutch.
Old Jul 3, 2002 | 01:01 PM
scorp508's Avatar
scorp508
Powershifting is most abusive to a car if you are sloppy on the shift or are trying it at a lousy shiftpoint. If you are fast & smooth with the motion then there should be little or no harm done to the synchros and clutch. It is the person who shifts lazily and allows the engine RPM to scream upwards that busts things up. :)
GM tests our drivetrains before they go to production. They do something crazy like 100 long passes with all full throttle shifts to make sure it holds up without ill effects.
Old Jul 3, 2002 | 09:27 PM
Knight Ryder
Thanks, Scorp. Yeah, I had visions of the engine revving way up between shifts. Makes sense. Maybe I'll go give it a try... :D
Old Jul 3, 2002 | 10:03 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: (Knight Ryder)
here's another video. You will have to crank it up to hear, but you can clearly see the tach and note the rpm.
http://temp.corvetteforum.net/c4/mrmojo2//shiftvid2.mpg
Old Jul 3, 2002 | 11:54 PM
Rynda's Avatar
Rynda
Default Re: (Mr Mojo)
Mr Mojo, Allright !!! Love it :D :yesnod: :yesnod:
I am agreeing with everyone who says when its done right, it doesn't hurt a thing. I've power shifted the vette many times. It is easier to do now that I have the B&M Ripper installed.
I also have a 1968 SS396 Camaro (now with a 454) that I have power shifted way more than a few times both with the 396 and the 454. I am still running the original transmission and rear end! I did shatter a relativly new universal joint once (the bearing cup to be exact). In the Camaro I can sidestep the clutch, I can't do that in the vette.
Old Jul 4, 2002 | 08:09 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
Default Re: (Rynda)
hey Frank, in second video, what RPM were you shifting at???? looks like you were past redline from that angle???? :confused:
Old Jul 4, 2002 | 12:41 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: (My 95)
Ken, I was shifting at about 6000(tach reading) never even came close to the rev limiter. I guess my tach is off by a bit.
To What is Power shifting?
Old Jul 4, 2002 | 12:46 PM
MY 95's Avatar
MY 95
interesting......I may give that a shot next time :)
Old Jul 4, 2002 | 03:42 PM
XtremeVette420's Avatar
XtremeVette420
Frank, your rpm needle seems really really loose to me. Might wanna have that looked at when you get the time. My fuel cutoff is right where GM says it is on my tach, hmmmm. Oh well, your the one with the fast times right, hehehe.
Old Jul 4, 2002 | 04:22 PM
J Z06's Avatar
J Z06
Default Re: (XtremeVette420)
I had a 'NERVOUS' or jumpy tach(I think it's a '90 thing) I just replaced it with an auto meter 2302 with mini-shift lite. It works well.
Frank is an awesome shifter! I've seen Him at the track,and it sounds TEXTBOOK every single time. He's not ashamed of beating the poor car in to the ground either :D
