Low temp fan switch issue.
Old Sep 24, 2013 | 06:48 PM
Mlrckm's Avatar
Mlrckm
1st Gear
Default Low temp fan switch issue.
I installed a low-temp fan switch this morning on my '95 LT1. The specs for the switch are the fans come on at 200 degrees and back off at 185. It was installed and wired just as the directions stated, but is not working as advertised. The fans come on when it reaches 228 and back off at 216. I double checked all connections and they are correct. Any ideas on what can be the problem? Any suggestions would be appreciated.
