Clearing ECM trouble codes
Old Sep 26, 2013 | 07:58 PM
86 coupe lover's Avatar
86 coupe lover
3rd Gear
Default Clearing ECM trouble codes
Does anyone have a clue why disconnecting my battery does not clear the trouble codes. I have left it unhooked for a couple of hours and the same ignition misfire and others are still there.
I caused this mess by trying to degrease my motor. I used a car wash degrease then rinsed with high pressure. The engine was ok but when I went around a corner it stated misfiring like crazy. Barely ran. I went to my shop and blew off everything with compressed air. Runs ok but Service light is lit and codes wont go away....
Old Sep 26, 2013 | 08:27 PM
3D-Aircrew's Avatar
3D-Aircrew
Default What codes?
If the trouble still exists the code will come back.
Old Sep 26, 2013 | 08:43 PM
vetteoz's Avatar
vetteoz
A code indicates you have a problem;
clearing the codes does not make the problem that caused the codes go away
You need to FIX something to get rid of the code(s)
Old Sep 26, 2013 | 08:48 PM
vetteoz's Avatar
vetteoz
The engine was ok but ... it stated misfiring like crazy. .
When asking for help on here you should always state year / engine , etc .
Many differences 84 - 96.
I assume you have a LT1 with the front mount "Opti Spark" dist which you have filled with water ; A big no -no on those engine.
You may fix the problem by dissembling the Opti and drying it out ; you may also be up for a new one
READ
http://www.lt1howto.com/articles/optisparkfaq.htm
Old Sep 27, 2013 | 12:55 PM
86 coupe lover
3rd Gear
It's an L98. Right now the idle is too high, slightly rough. Accelerates fine. I disconnected the battery for over an hour. Then I hooked it back up, and without starting the engine, read the codes. The same ones were still there. The codes came from when I had water on the motor.
It misfired and barely ran until I blew compressed air on motor. Then It seems ok, except for idle high (1500) and service engine light.
So my problem is how to clear the codes so that I can see what the current setup is, not when I foolishly tried to clean the motor....
Old Sep 27, 2013 | 04:38 PM
playsdixie's Avatar
playsdixie
welcome to the forum ...GIVE them the code....high idle indicates something is wrong...they can help you but you need to be specific....
Old Sep 27, 2013 | 05:09 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Most importantly do you know how to read the codes?
Or are you simply trying to clear the SES lite?
Sorry you can't use backyard shop logic to fix an ECM problem
Old Sep 27, 2013 | 06:31 PM
vetteoz's Avatar
vetteoz
.... read the codes. The same ones were still there. .
And they would be ........ ( holding breath ) .....?
Old Sep 28, 2013 | 02:06 AM
Cliff Harris's Avatar
Cliff Harris
It takes about 1 second to clear the codes. The easiest way is to open this connector (item 2 in the diagram):
To Clearing ECM trouble codes
