vacuum lines and misc hoses 85'
Old Sep 27, 2013 | 11:05 PM
85corvettec4's Avatar
85corvettec4
Default vacuum lines and misc hoses 85'
putting my injection together and trying to figure out where all these guys go, any help?
Old Sep 27, 2013 | 11:43 PM
vetteoz's Avatar
vetteoz
valve is the EGR solenoid
pipes are for the CCV /PCV system
vac line with T looks like off the AIR system
Old Sep 28, 2013 | 12:46 AM
85corvettec4
i cant make heads or tails of this. this must not be for my car.
Old Sep 28, 2013 | 12:59 AM
85corvettec4
like the air control valve only plugs into the TB not back into the egr
Old Sep 28, 2013 | 01:14 AM
Cliff Harris's Avatar
Cliff Harris
Here are a couple of pieces of your puzzle. These are the vacuum lines for the A.I.R. solenoids/valves. The other end goes to the front vacuum source on the rear of the plenum:
The short metal tube with the kink in the middle is the air supply for the PCV system. (it says "CCV" in the vacuum diagram). It goes in the passenger side valve cover:
The metal tube with the loop in the center is the A.I.R. coupling from the driver's side exhaust manifold to the passenger side exhaust manifold. The loop bolts to the top of the water pump. You can see it under the cold start thermo switch and CTS (Coolant Temperature Sensor) in the front of the intake manifold in this pic (the loop is in the lower right corner):
The setup with the molded right angle stuff is the EGR solenoid and vacuum lines. It was moved to the thermostat housing in 1986 -- the YDJ diagram is for 1986. Earlier it was mounted on the rear of the plenum on the passenger side.
The aluminum tube connects the intake manifold to the PCV valve and also goes to the charcoal canister (at the bottom of the picture).
Old Sep 28, 2013 | 01:26 AM
85corvettec4
rthe plug that connects to the egr solonoid also connects to a vacuum thing inbetween the ac and water pump
Old Sep 28, 2013 | 01:27 AM
85corvettec4
i cant find anothe electric plug for the egr. i also cant find a plug for my manifold temp sensor
Old Sep 28, 2013 | 01:31 AM
85corvettec4
Old Sep 28, 2013 | 01:36 AM
vetteoz's Avatar
vetteoz
Look harder
were told
so check for wires out of the main harness on firewall and the harrnss to the injectors on pass side of engine
Old Sep 28, 2013 | 01:44 AM
85corvettec4
this fits into the egr but it also fits into the plug right next to it. this is right next to dizzy.
Old Sep 28, 2013 | 01:51 AM
85corvettec4
i cant find any extra threads on my plenum either
Old Sep 28, 2013 | 02:01 AM
vetteoz's Avatar
vetteoz
The wire colors would help?
vetteoz's Avatar
vetteoz
For what ?
Old Sep 28, 2013 | 02:08 AM
85corvettec4
for where the solonoid would bolt up. and the plug i found is pink and gray wires
Old Sep 28, 2013 | 04:45 PM
85corvettec4
last pieace i havent figured out
Old Sep 28, 2013 | 06:23 PM
xrav22's Avatar
xrav22
Hey the egr plugs come off the drivers side fuel injector loom by the way. They only fit one way. Along with the maf sensor plug and those cold start sensors. The thing you are looking at here is the heater controller and the and the cruise control control. The l thing(my L rubber thing was loose so I use a big to little vacume adapter , it goes to the last little port on pass side(left) in the manifold. the long hose on there goes to the other side to a t connector (I mounted it by the battery) 1 end of t goes to cruise control and the other goes to the ball mounted by the left light. I fixed my heater doors and cruise works perfect. Oh the other empty end of the vacume controller(4 dollars at orielys) goes to a heater control vacume hose(hard line style) that should be lingering down by the egr solenoid(pass side of distributor).
Good luck
The egr threads are by the left rear of pass side manifold,1 bolt hard to see.
Well why u r at it you may as well change the large cruise control vacume hose(it goes into the firewall to the pedal) clean the plug and cross your fingers.
To get that vacume hose thru the firewall you will need to lube it up alot.
Old Sep 28, 2013 | 06:27 PM
85corvettec4
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
To vacuum lines and misc hoses 85'
Old Sep 28, 2013 | 06:31 PM
85corvettec4
i have a L plug in the back of the egr solonoid is that corrrect? it comes out from by the dizzy its like 2 inches long. and the only line i ssee coming out of the ball is plugged back into the canister through a LONG vac line.
Old Sep 28, 2013 | 06:53 PM
xrav22's Avatar
xrav22
Oops you may have made the same mistake as me. Nothing is on the back side it is a closed plastic. Looks like a connector! The 2 front hard lines go to the same as the pdf's to solenoid and air valves I think. Check it out. Trust me on the ball. The reason that line is so long I believe the vacume t I inserted mine near the cruise when originally the t was by the distributor.
Edit : Your egr sol has something at the back I have to go check mine out now. After further review I do not have an opening on the rear of the solenoid. I tried to stick a paper clip in. I read that an solenoid vent filter went to the back of 85 solenoid.
Old Sep 28, 2013 | 10:07 PM
xrav22's Avatar
xrav22
I uploaded a pic to my garage the t is where the red splits the yellow is the larger cruise hose that goes thru firewall
