Side to side rear play
Old Sep 29, 2013 | 11:53 AM
octaneforce's Avatar
octaneforce
Default Side to side rear play
So at autocross yesterday the tech inspector almost failed me because of some play in my rear wheels. I thought he was just being an **** d bag, but if i grab either of the rear wheels, there is a tiny bit of thunk thunk back and forth. Only about 1/8 of an inch but its there. They let me run that day but said i have to get it fixed before next time. Where do i start? I have yet to jack the car up but im looking for ideas. Ive never torn into this part of the car.
I also noticed that when im braking hard during autox, my rear tires shudder or "hop". I thought it was the nature of the beast but maybe its part of my issue
Old Sep 29, 2013 | 08:14 PM
Cyclonite's Avatar
Cyclonite
Do as rear end inspection. My wheel bearings went out and i had top-bottom play. Chrek all susp connections, and don't forget something as simple as torquing the lug-nuts!
If you are not familiar with doing the inspection: 1, get a manual to guide you and 2, ask another racer for info/assistance.
Old Sep 29, 2013 | 10:14 PM
93Rubie's Avatar
93Rubie
If everything checks ok and you still have the play. See if the stub axles in the diff. are sliding in and out some. Ask me how I know!!!
Old Sep 29, 2013 | 10:46 PM
383vett's Avatar
383vett
With the car off the ground, you will be able to see exactly where the play is coming from
To Side to side rear play
